Vand
Placa de baza Gigabyte
Procesor
1. Socket 478 for Intel® Pentium®4 with HT Technology
Chipset
1. Intel® 82845PE MCH
2. Intel® 82801DB ICH4
3. Realtek ALC650E/655 Audio AC'97 CODEC
4. Super I/O: ITE I/O IT8712F chip
5. 2M bit flash ROM
Front Side Bus
1. 533/400 MHz FSB
Memorie
1. Type: DDR266/333 ( PC2100/2700) 184 pin (2.5v)
2. 3 x DIMM
3. Max capacity: Up to 2 GB
Conectori I/O Interni
1. 1 x FDD
2. 2 x UDMA ATA 100/66 Bus Master IDE
3. 2 x USB 2.0 (4 ports by cable with rear USB bracket)
4. S/P DIF input/output (with rear bracket)
5. 3 x cooling fan pin headers
6. CD/AUX in
Sloturi de Expansiune
1. 1 x AGP 4x, supports 1.5v display card only.
2. 5 x PCI (PCI 2.2 compliant)
I/O pe Panoul din Spate
1. 2 x USB 2.0 ports
2. 1 x LPT
3. 2 x COM ports
4. Audio (1 x Line-in / 1 x Line-out / 1 x MIC) connector
5. PS/2 Keyboard/Mouse connector
6. 1 x Game/Midi port
Setări CPU/AGP/DIMM
1. CPU FSB / Multiplier / Vcore Voltage adjustable via BIOS
2. AGP Voltage / Clock adjustable via BIOS
3. DIMM Voltage / Clock adjustable via BIOS
Format
1. ATX
2. 29.5cm x 20.0cm
Monitorizare H/W
1. System health status auto-detect and report by BIOS
2. H/W detect and report power-in voltage, CPU voltage, and Fan speed
Alte Opţiuni
1. IDE #1-#4, SCSI, LS120, ZIP, CD-ROM and USB bootable.
2. Suspend to RAM (STR)
3. Supports USB KB / MS wake up from S3
Procesor Intel Pentium 4
Socket 478 FSB 533 2,88ghz
Placa video Nvidia Quadro FX 1400
* 128 MB DDR
* Dual DVI-I
* 3-pin mini-din Stereo connector
* Third-generation pixel and vertex programmability
* 128-bit IEEE floating-point precision graphics pipeline
* 128-bit color precision
* 12-bit sub-pixel precision
* 65,536 fragment instruction/65,536 vertex instruction
* 3D volumetric textures
* Hardware OpenGL overlays
* Hardware accelerated antialiased points and lines
* Hardware accelerated two-sided lighting
* Hardware accelerated clipping planes
* 3rd generation occlusion culling
* Rotated Grid full-scene antialiasing (4x)
* OpenGL quad-buffered stereo
* Optimized and certified for OpenGL 1.5 and DirectX 9.0c applications
* Multi-display productivity
PCIe x16 BUS
Pretul la placa de baza si procesor este de 200 ron
Pretul la placa video este de 200 ron
Contact 0748.131.998
spark2006_boy@yahoo.com ( mail si ID mess)
Pentru poze contactati
Procesor
Chipset
5. 2M bit flash ROM
Front Side Bus
1. 533/400 MHz FSB
Memorie
2. 3 x DIMM
1. 1 x FDD
6. CD/AUX in
2. 1 x LPT
3. 2 x COM ports
Setări CPU/AGP/DIMM
Format
1. ATX
2. 29.5cm x 20.0cm
Monitorizare H/W
Alte Opţiuni
* 128 MB DDR
* Dual DVI-I
PCIe x16 BUS
