[Vand] Consumabile si piese noi
  • Salut!
    vreau si eu un pret pentru consumabile (a doua revizie), a unui logan 1,6 16V euro 5:
    -ulei, sincer nu sunt decis, Castrol sau Elf (nici n-am citit topicul dedicat).
    -filtru ulei - MANN
    -filtru aer -
    -filtru polen(d-ala cu carbon vrăjit).
    -4 chedere de usi(post#1201 de MFLORIN)
    • Anunt valabil in continuare, precizez ca unele preturi se pot modifica ulterior ofertei afisate:
      - maneta stergatoare cu buton Cb la------------- 60 ron/buc
      - bloc lumini cu proiector model Valeo------------ 120 ron
      - bucsi bascule de origine ------------------------ 25 ron/buc
      - bujii Equiem cu 2 craci-------------------------- 60 ron/set
      - bujii Equiem cu 1 crac---------------------------50 ron/set
      - termostat (producator) LG diesel--------------- 115 ron
      - cap bara Lemforder ----------------------------- 85 ron/buc
      - bieleta directie Lemforder------------------------ 85 ron/buc
      - cap bara de origine------------------------------ 85 ron/buc
      - bielete directie de origine------------------------ 75 ron/buc
      - cap bara SWAG----------------------------------75 ron/buc
      - bielete directie SWAG----------------------------60 ron/buc
      - termostat benzina------------------------------- 35 ron
      - pivoti (LEMFORDER)------------------------------ 40 ron
      - bascula de origine------------------------------- 110 ron
      - set saboti (FERODO)----------------------------- 125 ron
      - nuca schimbator Prestige plastic------- ---------- 40 ron
      - nuca schimbator Prestige piele--------------------65 ron
      - bucsi bara stabilizatore mijloc -------------------- 35 ron/set
      - bielete antiruliu de origine ------------------------ 25 ron/buc
      - rulment roata fata FAG (fara ABS) ----------------105 ron/buc
      - set rulmenti roata fata FAG (fara ABS)-------------175 ron/set (2 buc)
      - burduf planetara stanga Logan---------------------80 ron
      - burduf planetara roata origine --------------------- 120 ron
      - filtru ulei original Purflux benzina ------------------- 20 ron
      - filtru ulei original Motorina ------------------------- 20 ron
      - filtru ulei MANN-FILTER----------------------------- 20 ron
      - filtru ulei DUSTER-----------------------------------30 ron
      - filtru aer benzina si motorina ----------------------- 25 ron
      - filtru aer MANN-FILTER (mpi) ----------------------- 33 ron
      - filtru aer MANN-FILTER (dci)-------------------------43 ron
      - filtru aer 16 valve --------------------------------- 25 ron
      - filtru motorina EURO 3 ---------------------------- 110 ron
      - filtru motorina EURO 4 ---------------------------- 110 ron
      - filtru polen Valeo ---------------------------------- 25 ron
      - oglinzi Prestige electrice ---------------------------250 ron/set
      - proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
      - buton reglaj oglinzi electrice ------------------------35 ron
      - buton deschidere usa -------------------------------10 ron
      - amortizoare Monroe fata ----------------------------120 ro/buc
      - amortizoare Monroe spate --------------------------105 ron/buc
      - amortizoare Bilstein B4 fata -------------------------145 ron/buc
      - amortizoare Bilstein B4 spate ------------------------125 ron/buc
      - flanse amortizor originale -----------------------------40 ron/buc
      - rulmenti amortizor SNR -------------------------------25 ron/buc
      - bieleta antirasturnare --------------------------------70 ron
      - bieleta antirasturnare VAN----------------------------80 ron
      - discuri frana VAN Brembo --------------------------- 135 ron/buc
      - placute frana VAN Ferodo SL ------------------------125 ron/set
      - placute frana VAN BOSCH ---------------------------150 ron/set
      - placute frana VAN TRW ----------------------------- 170 ron/set
      - discuri frana 259 pline Ferodo ------------------------190 ron/set
      - discuri frana 259 ventilate Ferodo --------------------210 ron/set
      - discuri frana 259 pline Brembo------------------------190 ron/set
      - discuri frana 259 ventilate Brembo---------------------240 ron/set
      - discuri fraba 259 ventilate Brembo Striate-------------390 ron/set
      - discuri frana ventilate RoadHouse---------------------140 ron/set
      - discuri frana ventilate Origine ------------------------260 ron/set
      - placute frana TRW ----------------------------------- 60 ron/set
      - placute frana Ferodo FQT ----------------------------125 ron/set
      - placute frana Ferodo Premier--------------------------95 ron/set
      - placute frana ORIGINE(FRANTA)------------------------120 ron/set
      - placute frana VAN (BOSCH)----------------------------140 ron/set
      - cablu ambreiaj MPI-DCI -------------------------------50 ron
      - cablu acceleratie MPI -------------------------------- 35 ron
      - sonda servodirectie -----------------------------------50 ron
      - sonda mers inapoi -------------------------------------35 ron
      - plafoniera 3 becuri ------------------------------------35 ron
      - plafoniera 1 bec ---------------------------------------30 ron
      - contactor lumina pedala frana ------------------------- 20 ron
      - spirala airbag volan ------------------------------------ 70 ron
      - kit distributie MPI -------------------------------------170 ron
      - pompa apa de origine MPI -----------------------------200 ron
      - pompa apa HEPU pt benzina ---------------------------175 ron
      - kit distributie DCI ------------------------------------- 260 ron
      - pompa apa DCI ----------------------------------------210 ron
      - kit ambreiaj SACHS 1.6 MPI ---------------------------- 380 ron/set
      - kit ambreiaj Origine 1.4 MPI-----------------------------340 ron/set
      - kit ambreiaj DCI producator LUK-------------------------350 ron
      - rulment ambreiaj hidraulic Valeo-------------------------170 ron
      - curele accesorii ---------------------------------------- 55 ron
      - kit accesorii MPI model cu AC de origine -----------------240 ron
      - kit accesorii DCI model cu AC de origine -----------------255 ron
      - role ghidaj MPI/DCI------------------------------------- 35 ron
      - spray luciu anvelope ------------------------------------25 ron
      - autocolante stalpi Prestige ------------------------------35 ron/set
      - aeratoare Prestige argintii -------------------------------65 ron/set
      - aeratoare Duster cromate--------------------------------60 ron/set
      - duze stropitor tip perdea------------------------------------20 ron/set
      - ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
      - ARAL HIGH TRONIC 5W-40 1L------------------30 ron
      - CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron
      - CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
      - CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron
      - CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron
      - CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
      - CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron
      - CAS EDGE 5W-30 5W-30 -1L ----------------51 ron
      - CAS EDGE 5W-30 5W-30 -4L ----------------190 ron
      - CAS EDGE 5W-30 5W-30 -5L ----------------215 ron
      - CAS MAGNATEC C3 5W-40 -1L ----------------35 ron
      - CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
      - CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron
      - CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron
      - CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron
      - CAS MAGNATEC BENZINA 10W-40 -1L-------------30 ron
      - CAS MAGNATEC BENZINA 10W-40 -4L-------------115 ron
      - CAS MAGNATEC BENZINA 10W-40 -5L--------------130 ron
      - CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron
      - CAS MAGNATEC DIESEL 10W-40 -4L---------------115 ron
      - CAS MAGNATEC DIESEL 10W-40 -5L---------------130 ron
      - ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron
      - ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron
      - ELF COMPETITION ST 10W-40/4L------------------85 ron
      - ELF COMPETITION ST 10W-40/1L------------------25 ron
      - ELF TURBO DIESEL 10W-40/5L---------------------110 ron
      - ELF TURBO DIESEL 10W-40/4L---------------------85 ron
      - ELF TURBO DIESEL 10W-40/1L---------------------25 ron
      - MOBIL SUPER 3000 5W-40/4L----------------------125 ron
      - MOBIL SUPER 3000 5W-40/1L-----------------------35 ron
      si multe altele...se pot aduce si piese pentru masini straine,
      mentionez ca piesele sunt de origine.
      evali_daniel este id-ul meu
      0766.403.938 Vali
      • salut bobina de inductie de 1,4 ai ceva?
        • ionell ai PM
          • duze tip perdea logan 2 mai ai ? ce pret ?
            My Ride ! B - 29 - TmT
            • Salut! Chederele pt usi se potrivesc si la PH2 ?
              Lume multa ...oameni putini .
              • Ai PM, domnu'!
                • Ai raspuns, stima.
                    0766.403.938 Vali
                    • carenaj roata dreapta fata ai cumva?
                      laureate 1.5l, albastru marin
                      • @ten nu am carenaje, imi pare rau.
                        • Salut evali_daniel.
                          Vreau si eu pentru maine cu predare in voluntari, urmatoarele:
                          capat bara stanga logan DCI origine -85 lei
                          capat bara dreapta logan DCI origine - 85 lei
                          Daca imi faci un pret bun per total vreau set capate bara+bielete directie stanga dreapta origine logan DCI.
                          Astept un mesaj de la tine daca ai piesele sa stabilim la ce ora ne intalnim.
                          Mersi frumos!
                          • salut.kit flansa amortizoare logan benzina aveti/daca da la ce pret/multumesc
                            • Sus cu anuntul!!!!
                              • salut,
                                un repartitor frana la ce pret il gasesc la tine?
