[Vand] Consumabile si piese noi
  • contactor pedala frana pt clio? cred ca e la fel ca ala de logan cu doi pini ( unu sus unul jos)
    Can't touch this !
    • @segaman nu am asa ceva, imi pare rau
      @ionut.11 ai PM
      • Ochii pisica pt bara spate ph2 si acel capac de la remorcare?
        • Anunt valabil in continuare, precizez ca unele preturi se pot modifica ulterior ofertei afisate:
          - maneta stergatoare cu buton Cb la------------- 60 ron/buc
          - bloc lumini cu proiector model Valeo------------ 120 ron
          - bucsi bascule de origine ------------------------ 25 ron/buc
          - bujii Equiem cu 2 craci-------------------------- 60 ron/set
          - bujii Equiem cu 1 crac---------------------------50 ron/set
          - termostat (producator) LG diesel--------------- 115 ron
          - cap bara Lemforder ----------------------------- 85 ron/buc
          - bieleta directie Lemforder------------------------ 85 ron/buc
          - cap bara de origine------------------------------ 85 ron/buc
          - bielete directie de origine------------------------ 75 ron/buc
          - cap bara SWAG----------------------------------75 ron/buc
          - bielete directie SWAG----------------------------60 ron/buc
          - termostat benzina------------------------------- 35 ron
          - pivoti (LEMFORDER)------------------------------ 40 ron
          - bascula de origine------------------------------- 110 ron
          - set saboti (FERODO)----------------------------- 125 ron
          - nuca schimbator Prestige plastic------- ---------- 40 ron
          - nuca schimbator Prestige piele--------------------65 ron
          - bucsi bara stabilizatore mijloc -------------------- 35 ron/set
          - bielete antiruliu de origine ------------------------ 25 ron/buc
          - rulment roata fata FAG (fara ABS) ----------------105 ron/buc
          - set rulmenti roata fata FAG (fara ABS)-------------175 ron/set (2 buc)
          - burduf planetara stanga Logan---------------------80 ron
          - burduf planetara roata origine --------------------- 120 ron
          - filtru ulei original Purflux benzina ------------------- 20 ron
          - filtru ulei original Motorina ------------------------- 20 ron
          - filtru ulei MANN-FILTER----------------------------- 20 ron
          - filtru ulei DUSTER-----------------------------------30 ron
          - filtru aer benzina si motorina ----------------------- 25 ron
          - filtru aer MANN-FILTER (mpi) ----------------------- 33 ron
          - filtru aer MANN-FILTER (dci)-------------------------43 ron
          - filtru aer 16 valve --------------------------------- 25 ron
          - filtru motorina EURO 3 ---------------------------- 110 ron
          - filtru motorina EURO 4 ---------------------------- 110 ron
          - filtru polen Valeo ---------------------------------- 25 ron
          - oglinzi Prestige electrice ---------------------------250 ron/set
          - proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
          - buton reglaj oglinzi electrice ------------------------35 ron
          - buton deschidere usa -------------------------------10 ron
          - amortizoare Monroe fata ----------------------------120 ro/buc
          - amortizoare Monroe spate --------------------------105 ron/buc
          - amortizoare Bilstein B4 fata -------------------------145 ron/buc
          - amortizoare Bilstein B4 spate ------------------------125 ron/buc
          - flanse amortizor originale -----------------------------40 ron/buc
          - rulmenti amortizor SNR -------------------------------25 ron/buc
          - bieleta antirasturnare --------------------------------70 ron
          - bieleta antirasturnare VAN----------------------------80 ron
          - discuri frana VAN Brembo --------------------------- 135 ron/buc
          - placute frana VAN Ferodo SL ------------------------125 ron/set
          - placute frana VAN BOSCH ---------------------------150 ron/set
          - placute frana VAN TRW ----------------------------- 170 ron/set
          - discuri frana 259 pline Ferodo ------------------------190 ron/set
          - discuri frana 259 ventilate Ferodo --------------------210 ron/set
          - discuri frana 259 pline Brembo------------------------190 ron/set
          - discuri frana 259 ventilate Brembo---------------------240 ron/set
          - discuri fraba 259 ventilate Brembo Striate-------------390 ron/set
          - discuri frana ventilate RoadHouse---------------------140 ron/set
          - discuri frana ventilate Origine ------------------------260 ron/set
          - placute frana TRW ----------------------------------- 60 ron/set
          - placute frana Ferodo FQT ----------------------------125 ron/set
          - placute frana Ferodo Premier--------------------------95 ron/set
          - placute frana ORIGINE(FRANTA)------------------------120 ron/set
          - placute frana VAN (BOSCH)----------------------------140 ron/set
          - placute frana origine(chiar origine)---------------------100 ron/set
          - cablu ambreiaj MPI-DCI -------------------------------50 ron
          - cablu acceleratie MPI -------------------------------- 35 ron
          - sonda servodirectie -----------------------------------50 ron
          - sonda mers inapoi -------------------------------------35 ron
          - plafoniera 3 becuri ------------------------------------35 ron
          - plafoniera 1 bec ---------------------------------------30 ron
          - contactor lumina pedala frana ------------------------- 20 ron
          - spirala airbag volan ------------------------------------ 70 ron
          - kit distributie MPI -------------------------------------170 ron
          - pompa apa de origine MPI -----------------------------200 ron
          - pompa apa HEPU pt benzina ---------------------------175 ron
          - kit distributie DCI ------------------------------------- 260 ron
          - pompa apa DCI ----------------------------------------210 ron
          - kit ambreiaj SACHS 1.6 MPI ---------------------------- 380 ron/set
          - kit ambreiaj Origine 1.4 MPI-----------------------------340 ron/set
          - kit ambreiaj DCI producator LUK-------------------------350 ron
          - rulment ambreiaj hidraulic Valeo-------------------------170 ron
          - curele accesorii ---------------------------------------- 55 ron
          - kit accesorii MPI model cu AC de origine -----------------240 ron
          - kit accesorii DCI model cu AC de origine -----------------255 ron
          - role ghidaj MPI/DCI------------------------------------- 35 ron
          - spray luciu anvelope ------------------------------------25 ron
          - autocolante stalpi Prestige ------------------------------35 ron/set
          - aeratoare Prestige argintii -------------------------------65 ron/set
          - aeratoare Duster cromate--------------------------------60 ron/set
          - duze stropitor tip perdea---------------------------------15 ron/set
          - carenaje roti origine--------------------------------------65 rom/buc
          - chedere scurte usi Logan ---------------------------------5 ron/buc
          - ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
          - ARAL HIGH TRONIC 5W-40 1L------------------30 ron
          - CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron
          - CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
          - CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron
          - CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron
          - CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
          - CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron
          - CAS EDGE 5W-30 5W-30 -1L ----------------51 ron
          - CAS EDGE 5W-30 5W-30 -4L ----------------190 ron
          - CAS EDGE 5W-30 5W-30 -5L ----------------215 ron
          - CAS MAGNATEC C3 5W-40 -1L ----------------35 ron
          - CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
          - CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron
          - CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron
          - CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron
          - CAS MAGNATEC BENZINA 10W-40 -1L-------------30 ron
          - CAS MAGNATEC BENZINA 10W-40 -4L-------------115 ron
          - CAS MAGNATEC BENZINA 10W-40 -5L--------------130 ron
          - CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron
          - CAS MAGNATEC DIESEL 10W-40 -4L---------------115 ron
          - CAS MAGNATEC DIESEL 10W-40 -5L---------------130 ron
          - ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron
          - ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron
          - ELF COMPETITION ST 10W-40/4L------------------85 ron
          - ELF COMPETITION ST 10W-40/1L------------------25 ron
          - ELF TURBO DIESEL 10W-40/5L---------------------110 ron
          - ELF TURBO DIESEL 10W-40/4L---------------------85 ron
          - ELF TURBO DIESEL 10W-40/1L---------------------25 ron
          - MOBIL SUPER 3000 5W-40/4L----------------------125 ron
          - MOBIL SUPER 3000 5W-40/1L-----------------------35 ron
          si multe altele...se pot aduce si piese pentru masini straine,
          mentionez ca piesele sunt de origine.
          evali_daniel este id-ul meu
          0766.403.938 Vali
          • Valabil in continuare....
            • Ai timonerie pentru un Logan 1.4?
              • gasesc la tine vasul de expansiune pentru logan
                • Salut
                  sunt la acelasi pret?
                  sau nu ai kit complet si cu piulita si cupela de deasupra?
                  • Hector2, ai PM
                    • - discuri frana 259 ventilate Brembo Striate-------------390 ron/set
                      Merg pe diesel? S-a modificat pretul? La ce bani e sa ajunga la Pitesti?
                      • Salut, discurile sunt aceseta din poza, si merg pe diesel pretul este de 400 ron /set.
                        • Update la citeva repere:
                          - kit distributie DCI origine----------- 230 ron/kit
                          - pompa apa DCi origine ------------- 180 ron
                          - kit distribuitie MPI origine----------- 140 ron/kit
                          - pompa apa MPI origine ------------- 170 ron
                          • - set chedere suplimentare usi----------25 ron
                            • Am primit coletul. Sanatate!
                              • cu placere
