[Vand] Consumabile si piese noi
  • oglinda stanga pentru logan mcv 2010, astept pm cu pret
    • cat costa niste chedere de duster? Multumesc
      My ride
      • Valabil in continuare:
        - set duze strpitor perdea---------------15 ro/set
        - bieleta antirasturnare aluminiu----------80 ron
        - bieleta antirasturnare ------------------70 ron
        - bascule origine-------------------------145 ron
        - obturatoare praf------------------------20 ron/set
        - set chedere usi scurte Logan nou--------20 ron/set
        si multe altele
        0766.403.938 Vali
        • tripla spate dreapta logan 2010 la ce pret?
          Asigurari Rca, Casco,Locuinta, Viata,etc...
          • @lucian ai PM
            Valabil in continuare.
            • Anunt valabil in continuare, precizez ca unele preturi se pot modifica ulterior ofertei afisate:
              - maneta stergatoare cu buton Cb la------------- 60 ron/buc
              - bloc lumini cu proiector model Valeo------------ 120 ron
              - bucsi bascule de origine ------------------------ 25 ron/buc
              - bujii Equiem cu 2 craci-------------------------- 60 ron/set
              - bujii Equiem cu 1 crac---------------------------50 ron/set
              - termostat (producator) LG diesel--------------- 115 ron
              - cap bara Lemforder (cu arc)--------------------- 85 ron/buc
              - bieleta directie Lemforder------------------------ 85 ron/buc
              - cap bara de origine(cu arc)---------------------- 85 ron/buc
              - bielete directie de origine------------------------ ron/buc
              - cap bara SWAG----------------------------------75 ron/buc
              - bielete directie SWAG----------------------------60 ron/buc
              - termostat benzina------------------------------- 35 ron
              - pivoti (LEMFORDER)------------------------------ 40 ron
              - bascula de origine------------------------------- 110 ron
              - set saboti (FERODO)----------------------------- 125 ron
              - nuca schimbator Prestige plastic------- ---------- 40 ron
              - nuca schimbator Prestige piele--------------------65 ron
              - bucsi bara stabilizatore mijloc -------------------- 35 ron/set
              - bielete antiruliu de origine ------------------------ 25 ron/buc
              - rulment roata fata FAG (fara ABS) ----------------105 ron/buc
              - set rulmenti roata fata FAG (fara ABS)-------------175 ron/set (2 buc)
              - burduf planetara CV stanga Logan------------------80 ron
              - filtru ulei original Purflux benzina ------------------- 20 ron
              - filtru ulei original Motorina ------------------------- 20 ron
              - filtru ulei MANN-FILTER----------------------------- 20 ron
              - filtru ulei DUSTER-----------------------------------30 ron
              - filtru aer benzina si motorina ----------------------- 25 ron
              - filtru aer MANN-FILTER (mpi) ----------------------- 33 ron
              - filtru aer MANN-FILTER (dci)-------------------------43 ron
              - filtru aer 16 valve --------------------------------- 25 ron
              - filtru motorina EURO 3 ---------------------------- 110 ron
              - filtru motorina EURO 4 ---------------------------- 110 ron
              - filtru polen Valeo ---------------------------------- 25 ron
              - oglinzi Prestige electrice ---------------------------250 ron/set
              - proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
              - buton reglaj oglinzi electrice ------------------------35 ron
              - buton deschidere usa -------------------------------10 ron
              - amortizoare Monroe fata ----------------------------115 ro/buc
              - amortizoare Monroe spate --------------------------105 ron/buc
              - amortizoare Bilstein B4 fata -------------------------145 ron/buc
              - amortizoare Bilstein B4 spate ------------------------125 ron/buc
              - flanse amortizor originale -----------------------------40 ron/buc
              - rulmenti amortizor SNR -------------------------------25 ron/buc
              - bieleta antirasturnare --------------------------------70 ron
              - bieleta antirasturnare VAN----------------------------80 ron
              - discuri frana VAN Brembo --------------------------- 135 ron/buc
              - placute frana VAN Ferodo SL ------------------------125 ron/set
              - placute frana VAN BOSCH ---------------------------150 ron/set
              - placute frana VAN TRW ----------------------------- 170 ron/set
              - discuri frana 259 pline Ferodo ------------------------190 ron/set
              - discuri frana 259 ventilate Ferodo --------------------200 ron/set
              - discuri frana 259 pline Brembo------------------------190 ron/set
              - discuri frana 259 ventilate Brembo---------------------240 ron/set
              - discuri fraba 259 ventilate Brembo Striate-------------390 ron/set
              - discuri frana ventilate RoadHouse---------------------140 ron/set
              - discuri frana ventilate Origine ------------------------260 ron/set
              - placute frana TRW ----------------------------------- 60 ron/set
              - placute frana Ferodo FQT ----------------------------125 ron/set
              - placute frana Ferodo Premier--------------------------95 ron/set
              - placute frana ORIGINE(FRANTA)------------------------120 ron/set
              - placute frana VAN (BOSCH)----------------------------140 ron/set
              - cablu ambreiaj MPI-DCI -------------------------------50 ron
              - cablu acceleratie MPI -------------------------------- 35 ron
              - sonda servodirectie -----------------------------------50 ron
              - sonda mers inapoi -------------------------------------35 ron
              - plafoniera 3 becuri ------------------------------------35 ron
              - plafoniera 1 bec ---------------------------------------30 ron
              - spirala airbag volan ------------------------------------ 70 ron
              - kit distributie MPI -------------------------------------170 ron
              - pompa apa de origine MPI -----------------------------200 ron
              - pompa apa HEPU pt benzina ---------------------------175 ron
              - kit distributie DCI ------------------------------------- 260 ron
              - pompa apa DCI ----------------------------------------210 ron
              - kit ambreiaj SACHS 1.6 MPI ---------------------------- 380 ron/set
              - kit ambreiaj Origine 1.4 MPI-----------------------------340 ron/set
              - kit ambreiaj DCI producator LUK-------------------------350 ron
              - rulment ambreiaj hidraulic Valeo-------------------------170 ron
              - curele accesorii ---------------------------------------- 55 ron
              - kit accesorii MPI model cu AC de origine -----------------240 ron
              - kit accesorii DCI model cu AC de origine -----------------255 ron
              - role ghidaj MPI/DCI------------------------------------- 35 ron
              - spray luciu anvelope ------------------------------------25 ron
              - autocolante stalpi Prestige ------------------------------35 ron/set
              - aeratoare Prestige argintii -------------------------------65 ron/set
              - aeratoare Duster cromate--------------------------------60 ron/set
              - duze stropitor tip perdea---------------------------------15 ron/set
              - set chedere scurte Logan nou----------------------------20 ron/set
              - obturatoare praf ----------------------------------------20 ron/set
              - ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
              - ARAL HIGH TRONIC 5W-40 1L------------------30 ron
              - CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron
              - CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
              - CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron
              - CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron
              - CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
              - CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron
              - CAS EDGE 5W-30 5W-30 -1L ----------------51 ron
              - CAS EDGE 5W-30 5W-30 -4L ----------------190 ron
              - CAS EDGE 5W-30 5W-30 -5L ----------------215 ron
              - CAS MAGNATEC C3 5W-40 -1L ----------------35 ron
              - CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
              - CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron
              - CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron
              - CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron
              - CAS MAGNATEC BENZINA 10W-40 -1L-------------30 ron
              - CAS MAGNATEC BENZINA 10W-40 -4L-------------115 ron
              - CAS MAGNATEC BENZINA 10W-40 -5L--------------130 ron
              - CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron
              - CAS MAGNATEC DIESEL 10W-40 -4L---------------115 ron
              - CAS MAGNATEC DIESEL 10W-40 -5L---------------130 ron
              - ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron
              - ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron
              - ELF COMPETITION ST 10W-40/4L------------------85 ron
              - ELF COMPETITION ST 10W-40/1L------------------25 ron
              - ELF TURBO DIESEL 10W-40/5L---------------------110 ron
              - ELF TURBO DIESEL 10W-40/4L---------------------85 ron
              - ELF TURBO DIESEL 10W-40/1L---------------------25 ron
              - MOBIL SUPER 3000 5W-40/4L----------------------125 ron
              - MOBIL SUPER 3000 5W-40/1L-----------------------35 ron
              si multe altele...se pot aduce si piese pentru masini straine,
              mentionez ca piesele sunt de origine.
              evali_daniel este id-ul meu
              0766.403.938 Vali
              • Multumesc Vali pentru promptitudine si ajutor!
                Am comandat discuri, placute,capete de bara..piese originale.
                • Mersi Laur, sa ai frane bune.
                  • Un pret pentru un filtru combustibil pentru 1, 5 dci E5, 8201046788 ?
                    Mersi.
                    • IancuMic, am filtru, ai PM.
                      • Vali, doar saboti FERODO ai? Poti face rost si de cilindrii receptori? Ms
                        • Laur am, ai PM
                            - cap bara de origine(cu arc)---------------------- 100 ron/buc
                            - bielete directie de origine------------------------ lipsa stoc
                            - amortizoare Monroe spate -------------------------- 105 ron/buc
                            - amortizoare Bilstein B4 fata ------------------------- 145 ron/buc
                            - placute frana VAN TRW -----------------------------170 ron/set
                            - placute frana ORIGINE(FRANTA)------------------------100 ron/set
                            - kit distributie MPI -------------------------------------150 ron
                            0766.403.938 Vali
                            • Salut, chederele tip streasina ce vin fixate pe cupola caroseriei la Logan 2 poti aduce si la ce pret?
                              Cu stima
                              • Butoane geamuri
                                Salut.
                                Butoane deschidere geamuri PH1 cu impuls?
                                Merci.
