[Vand] Amplificator Rx Mono Magnat
  • [Vand] Amplificator Rx Mono Magnat
    Produsul Functioneaza impecabil 8 luni vechime
    * amplificator auto mono
    * putere
    o 4 ohmi: 1 x 350W RMS (1 x 1000W max)
    o 2 ohmi: 1 x 500W RMS (1 x 1400W max)
    o 1 ohm: 1 x 800W RMS (1 x 2000W max)
    * Raspuns in frecventa 5 - 250 Hz
    * THD < 0,05 % (1 kHz)
    * filtru LPF variabil 40-250 Hz, 12 dB
    * filtru subsonic variabil 10-40 Hz, 12 dB
    * Bass boost variabil 0-15 dB la 45 Hz
    * dimensiuni: 450 x 50 x 261 mm
    * intrari / iesiri RCA aurite
    * control volum remote (telecomanda pe fir)
    550 ROn
    Va multumesc!
    Greseala
    Amplificator mono
    Putere maxima la 4 ohmi: 1x1000w
    Putere RMS la 4 ohmi: 1x500w
    Putere maxima la 2 ohmi:1x1400w
    Putere RMS la 2 ohmi: 1x700w
    Putere maxima la 1 ohm: 1 x 2000w
    Putere RMS la 1 ohm: 1x1000w
    Frecventa de raspuns: 5-250 Hz
    Variable low pass channel 1 from 40 Hz
    Variable low pass channel 1 to 250 Hz
    Subsonic filter channel 1 from 10 Hz
    Subsonic filter channel 1 to 40 Hz
    Bass Boost: 1 - 12 dB
    Dimensiuni:450x450x261mm
    Greutate: 4,85 kg
    negociabil.... am uitat sa specific
      Mai vand urmatoarele:
      - Pionner DEH-P6000UB - ca nou 2 zile de proba
      - Amplificator magnat 4 canale ultra 4000 noua
      - Sistem de boxe 13'' Ground zero nedesfacute
      - Boxe dcx 690 Hertz - 2 luni fara blana
      - Amplificator Rx Mono - 8 luni folosita cu un difuzor de 350 de la alpine
        nimeni nimic?
          Pune si pretul la cele mentionate mai sus.Multumesc!
          sigpicLogan Laureate - 1.5 DCI
            Pionner DEH-P6000UB 500ron - neg
            Amplificator magnat 4 canale ultra 4000 200ron - neg
            Boxe Ground Zero GZTC 130T 250Ron - neg
            Boxe dcx 690 Hertz 200Ron - neg
            Amplificator Rx Mono 500Ron - neg + Cablaraia + rezistenta + 2 adaptoare pt a conecta 2 stati pe un singur cablu. de + si -
              negocieri?
