[VAND] Multimedia Auto
  • [VAND] Multimedia Auto
    ICE - In car entertainment – LOW COST :
    Radio- CD MP3
    Boxe
    Monitoare LCD
    DVD-uri
    PlayStation 2
    Subwoffer
    Amplificatoare
    CAR PC
    GPS
    Car Kit-uri
    Si alte produse similare din gama LOW COST
    De asemenea facem si sonorizari Profi cu produse din gama Hertz, Focal si Audioson
    Tuning :
    - Elemente de caroserie din fibra precum si reparatii minore in fibra
    Contact:
    Y! : tpghites
    Skype: tpghites
    Tel: 0744 40 68 65
    Oferta valabila din 8.05.2007 pana in 15.06.2007 , in limita stocului disponibil.
    Produsele sunt noi cu garantie. pret special 625 ron tva inclus
    Amplificator MTX XTHUNDER X502 2 canale + boxe componente 16.5 cm MTX THUNDER THS 652
    specificatii amplif
    CEA RMS Power : 2x50W @ 4Ohm, 14,4 Volts
    CEA RMS Power : 2x90W @ 2Ohm, 14,4 Volts
    CEA RMS Power : 1x180W @ 4Ohm Bridged, 14,4 Volts
    X-over : High pass 12dB variable from 40 to 8kHz
    X-over : Low pass 24dB variable from 40 to 8kHz
    X-over : Band pass 12dB variable from 40 to 8kHz
    Minimum Impedance : 2Ohm stereo or 4Ohm bridged
    Frequency response : 20Hz - 20kHz ±1dB
    THD+N / 1W : <0,1%
    S/N ratio : 85dB
    Sensitivity : 0,2 to 5Volts
    Dimensions : 18,5x21,0x5,0cm
    specificatii boxe:
    RMS Power : 65W
    Max Power : 260W
    Impedance : 4 Ohm
    Frequency response : 66Hz - 25kHz
    Sensitivity : 91,0 dB/2,83v/1m
    Tweeter : 19mm Silk dome
    Tweeter Cut-out diameter : 40,6mm
    Tweeter mounting depth : 13,8mm
    Woofer diameter : 16,5cm
    Woofer Cut-out diameter : 142mm
    Woofer mounting depth : 66mm
    Injected polypropylene cone with aluminium finish
    Black rubber surround
    2,5 cm Aluminium voice coil
    Solid Aluminium phase plug
    Original MTX Euro DIN basket
    Oversized magnet
    Rubber magnet cover with MTX logo
    Silk dome tweeter with MTX original phase plate
    Flush or eyeball installation options for the Tweeter
    2-way 6dB/oct x-over
    X-over with high quality components (poly cap and air core coil)
    With tweeter protection
    High power handling
    High Sound Quality
    Including multi way useable speaker grills
    Including mounting material and wires
    Produsele sunt noi cu garantie. pret special 485 ron tva inclus
    Amplificator MTX XTHUNDER X502 2 canale + boxe coaxiale 13 cm MTX THUNDER THX 502
    specificatii amplif
    Frequency response : 20Hz - 20kHz &plusmn;1dB
    THD+N / 1W : <0,1%
    S/N ratio : 85dB
    specificatii boxe:
    RMS Power : 55W
    Max Power : 220W
    Impedance : 4 Ohm
    Frequency response : 65Hz - 22kHz
    Sensitivity : 91,5 dB/2,83v/1m
    Tweeter : 13mm PEI dome
    Diameter : 13cm
    Cut-out diameter : 117mm
    Depth : 49mm
    Tweeter with MTX original phase plate
    Pivoting tweeter
    Oversized magnet
    High power handling
    High Sound Quality
    doua tetiere cu monitoare se gasesc si la ce pret.culoare gri.
    LOGAN--> <--TOYOTA
      Monitor LCD 7" cu tot cu tetiera pe gri avem la 247 euro cu tot cu TVA.
        Daca in 48 de ore nu apare linkul site-ului nostru undeva pe site-ul dvs, anuntul dispare.
          In perioada 11.05.2007 - 18.05.2007 in limita stocului disponibil Senzori de parcare cu montajul inclus:
          Senzori de parcare cu indicator: 105 euro cu montajul inclus
          Senzori de parcare cu oglinda : 120 euro cu montajul inclus
          Preturile sunt finale si au inclus TVA
          Plata se va face in lei la curs BRD al zilei respective
            Promotia pentru senzorii de parcare se prelungeste pana pe data pe 25.05.2007
            Aveti mai jos cateva poze cu 2 masini la care s-au instalat senzori de parcare chiar azi
