vand 2 midbassi de la Audio Development o firma din Italia cunoscuta si in Germania, SUA. Seria este W600 de 16.5cm am doar midbassi grilele si partea de plastic in care stau, functional perfect estetic bun,
de noi impreuna cu tweeterele sunt 300E
pret 300ron usor negociabil, se trimite prin ce doreste cumparatorul
specificatii mai jos si poze
Fibreglass cone rubber suspension, 2 konex spiders , ferrite midwoofer W600
D-16.5 (cm),
Re 3.2 ohm,
Fs (Hz) 65,
Vas (litri) 7.53,
Qts 0.65,
Qms 4.2,
BxL 5.85,
Le (mH) 0.76,
Xmax (mm) 18,
Freq Response 45-2.500 Hz,
Power (W) 150,
SPL (dB) 90,
Prof (mm) 67.5,
Hole D. (mm) 141
am citit regulamentul si sunt 100% pro el
D-16.5 (cm),
Re 3.2 ohm,
Fs (Hz) 65,
Vas (litri) 7.53,
Qts 0.65,
Qms 4.2,
BxL 5.85,
Le (mH) 0.76,
Xmax (mm) 18,
Power (W) 150,
SPL (dB) 90,
Prof (mm) 67.5,
Hole D. (mm) 141
