VAND MP3 Player Auto, Boxe Ovale, Statie Si Subwoofer PIONEER
  • VAND MP3 Player Auto, Boxe Ovale, Statie Si Subwoofer PIONEER
    Vand urmatoarele scule:
    vand amplif pioneer gm 3200t
    amplificator 2 canale
    putere Max: 2 x 120W sau 1 x 300W (4 Ohm)
    filtru LPF: 80 Hz, -12 dB/Oct
    nivel semnal intrare: 400 mV - 6.5 V
    distorsiuni < 0.008 %
    raport semnal/zgomot (S/N ratio) > 100dB
    dimensiuni: 300 x 61 x 195 mm
    greutate: 2.7 kg
    360 lei, am factura, cutia si garantia.
    il vand pentr ca fac upgrade.
    un set difuzoare ovala pioneer TS-A6911. La beloud. Ro sunt 250 lei, eu le dau cu 140 lei. Sunt in garantie si putin folosite.
    difuzoare pe 3 cai
    dimensiune 6 x 9"
    putere: 80W RMS (330W max)
    SPL: 93 dB
    impedanta 4 ohmi
    raspuns in frecventa: 25 - 30.000 HzHz
    diametru tweeter midrange: 57,0 mm
    diametru tweeter: 18,0 mm
    un set difuzoare pentru usi pioneer TS-G1349 la 70 lei.
    Difuzoare coaxiale 2 cai
    diametru: 13 cm
    putere 25W RMS (130W max)
    impedanta: 4 Ohm
    raspuns in frecventa 50-25000 Hz
    sensibilitate (1W/1m): 89dB
    membrana din polipropilena
    Cd player cu mp3 pioneer DEH p 4800MP la 450 lei
    Radio CD si MP3 player auto
    amplificare interna 4x50W, MOSFET
    procesare sunet: HPF, LPF, EEQ Plus, FIE (Front Image Enhancer), SFEQ (Sound Focus Equaliser)
    panou frontal detasabil
    buton volum rotativ
    Compatibil CD-R,CD-RW, MP3, WMA, WAV, CD-Text
    tuner compatibil RDS
    iesiri preout RCA: 2 (F, R sau S/W)
    intrare AUX-In
    IP-Bus
    toate au cutie, carti, accesorii si garantie.
    subwoofer Pioneer TS SW841D
    Specificatii
    Marime - 8" sau 20 cm
    Putere muzicala maxima - 500 Watts
    Putere nominala RMS - 120 Watts
    Frecventa de raspuns - 30 ~ 1,500Hz
    Senzitivitate - 85dB
    Impedanta - 4 ohm
    Inchidere recomandata - 0.15 ~ 0.5 Cubic Feet
    Dimensiuni - 8-7/8" x 3"
    Adancimea de montaj - 63.5 mm
    Descriere
    Woofer Cone Material Composite IMPP using Interlaced Carbon Fiber and Ultra Long Glass Fiber
    Woofer Cone Design Double Cone with Air Suspension Control System
    Surround 3-Layer Fiber Woven Radial Surround with M-shape Cross-section
    Voice Coil 4 Layer, Long Voice Coil
    Voice Coil Wire Copper
    Voice Coil Bobbin Glass Cloth
    Damper (Spider) None (Air Suspension Control System)
    Top Plate T-Pole Yoke
    Projected Pole Yoke with Vented Pole
    Magnet Construction Strontium
    Basket Design Cast Aluminum Basket with Fin-Shaped Design
    Gasket Rubber
    Wire Terminals Spring Compression
    Se vinde si cu incinta din poza la 500 lei.
    Ride Like The Wind!
    Silviu iti dau 50 pe difurile de 13` si mi le trimiti prin posta!?
    Am scos masina in ploaie sa se tuneze cand tuna !.......restul e LOGAN
      Nimeni interesat?
      Ride Like The Wind!
        Preturi negociabile
        Ride Like The Wind!
          Pai eu ti-am zis ca iti dau pe difurile de 13' daca le trimiti prin posta 50 RON.
            Si eu ti-am raspuns: ti le trimit prin posta dar vreau 60 pe ele.
            Ride Like The Wind!
              Up!!!!!!!!!!!!
              Ride Like The Wind!
                Bine hai ca mai convins! Le iau cu 60.
                Ai PM!!
                  Boxele de 13" s-au dat, au mai ramas celelalte componente.
                  Ride Like The Wind!
                    s-au dat si boxele ovale, mai sunt la vanzare: playerul, statia si subwooferul.
                    Ride Like The Wind!
                      Va doresc sarbatori fericite!
                      Ride Like The Wind!
                        nu e nimeni interesat?
                        Ride Like The Wind!
                          cat ar fi acuma pretul pentru toate trei?daca mai sunt de vanzare binenteles.Mersi
                          http://img94.imageshack.us/img94/4346/fanecl.gif
                            au mai ramas doar cd playerul la 400 si subwooferul la 500. daca le iei pe amandoua negociem.
                            Ride Like The Wind!
                              upppppppp !
                              Ride Like The Wind!
