Common Problems
  • Common Problems
    Dear freinds
    i have a suggest.we have this car around of world as (nissan aprio-dacia logan-renault logan- tondar90) pls write problems english if possible because of useful information and how can solve our problems.
    best regards:Flower:
    There seems like there are too little problems with the car.
    The only thin I noticed by now at my baby, is that the rear marsh-arriere lamp does not turn on every time. And the part of the dashboard with the heat, ventilator, and ventilation exit-positions, that the illumination does not work.
    I think, that I've token too much pottholes with it.
    The rest of it, it's OK, no engine or other problems with it.
    It's really reliable.
    MORAL: Don't take too much potholes, it can damage the car in one or another way!
    http://img258.imageshack.us/img258/5371/loganmt0.jpg
    http://img87.imageshack.us/img87/133...6363089mj1.png
      Problems avto:
      1. Forward omentums of the engine - a guarantee case flow.
      2. Bearings of forward naves - a guarantee case.
      3. Steering drafts - deterioration.
      4. Bulbs of light - fuse through a floor of year.
      5.In Russia the some people Logany have the centers of corrosion. The paint on a roof and wings rusts.
      Excuse me for bad English
        Dear Friends
        i have problem with Reverse Gear ,some times i cant shift it from natural to reverse.
          You grind the gears right???.....You must push the accelerator a bit....Just touch it slightly then shift
            I do it ,but any thing not changed.
              Press again the clutch pedal .... Release the pedal and press it back and try to shift again .
                hamid, try to engage 1st or 2nd gear, without releasing the clutch. Just engage and disengage the gear, then you should be able to get into reverse with only a short "click" of the gearstick.
                  CSEBALYN,your suggest is good, but sometimes have some noise .
                    The noise is something "normal" for Logan's gearbox, with many cheap solutions.
                    But, stop the car before moving your shiftstick in marsharriere position.
                    • #11
                      As RAZZVAN said, try the "double clutch" :
                      -press clutch>change from the forward gear to neutral>release clutch>press clutch>change to reverse gear.
                      This supposed to help you getting rid of that "grinding" noise.
                      Success!
                      or
                      وكما قال razzvan ، جرب مزدوجة "الفاصل" :
                      - الصحافة التشبث> من التغيير إلى الأمام والعتاد محايدة> الافراج عن التشبث> الصحافة التشبث> لعكس اتجاه التغيير والعتاد.
                      هذا من المفترض ان تساعدك على التخلص من ان "طحن" الضوضاء.
                      النجاح!
                      sigpicLaureate 2007 GPL
                      • #12
                        Dear coldon
                        i dont know arabic language.
                        • #13
                          Doesn't matter at all. What about that annoing noise?
                          farsi not available yet, sorry!
                          Success!
                          • #14
                            Dear Coldun
                            the noise exist.
                            • #15
                              Dear Coldun
                              do you have anuual loganist ceremony in romania?
