Erori senzori presiune roti
  • #31
    E fix aceeași eroare: eroare de compensare, semnal implauzibil.
    • #32
      Originally posted by Zepelinul123 View Post
      Mi-a spus la 28, eu am 29 acum, difera ultima cifra daca te utii atent
      The last two digits are DTC status information. Use the Pyren software, to see, if the bug has the status present or saved.
      • #33
        Pyren also defines the errors in plain text in your language.
        • #34
          As usually you are right, with PyRen we can see and analyze errors much better and correctly. In post # 9 I attached some screenshots, I am still attaching with the only errors I have had so far (after 4 years) on the car. Then I had DF364 (DTC5A607B), the left rear wheel had -0.3 bar less, the indirect TPMS system detected this, after a few months (and changing tires) I had the same error but with the right front wheel, since then the errors in all car computers there were zero (and I hope it stays that way).
          Of course, we still do not know which machine or TPMS system indirectly or directly (quite likely) has the colleague, but I have attached the screenshots for example, plus those with error DTC5A8468xx and a file DTC5A8468xx.docx with related errors (diagnosis, calibration, writing, identification, etc. sensors) may be are useful to other colleagues also.
          @ eastcowboy, I appreciate your experience, work and time and I want to thank you again for all the help and support provided so far to us.
          Greetings and all the best!
          • #35
            But I have a generic renolink interface, can this support PyRen ?
            • #36
              yes, if you are using a current Pyren update. Older versions do not support the 1000000 baud rate setting with renolink.
              • #37
                Da, daca interfata ObdLink(SX) este OK atunci se poate folosi si cu PyRen.
                Dar in continuare puneti doar intrebari fara sa oferiti detaliile necesare (toate de cele de pana acum clar ca sunt "contradictorii") sau sa raspundeti la intrebarile puse.
                Intreb din nou: masina este sau nu pana la urma a dumeavoastra, din ce an si ce model este (seria de sasiu necesara), daca nu atunci macar faceti ceva "arginti" cu ajutorul primit?
                Iar eventualele raspunsuri ar fi bine sa fie macar acum oneste si corecte, pentru ca se pot gasi\verifica foarte usor pe "net", plus ca nu e o problema cu asta, si cei care "presteaza servicii" pot obtine ajutor\informatii pe forumuri (iar acesta este benevol si nu o obligatie).
                Numai de bine!
                • #38
                  Iar cele scrise cel putin in posturile #3, 5, 25 raman valabile (si subscriu), plus ca o interfata si un program de diagnoza corespunzatoare clar ca ajuta daca sunt folosite asa cum trebuie iar "rezultatele" analizate si interpretate corect, dar nu neaparat rezolva si problema(ele), asta mai implica si "alte cele" (iar dupa\despre ce a tot intrebat initiatorul atat aici cat si pe alte forumuri....).
                  • #39
                    Am inlocuit supapa cu senzor de pe spate- dreapta si s-a rezolvat. Acel senzor are o baterie ca de ceas in ea, dar mi s-a spus ca nu se poate schimba doar aceea.
                    • #40
                      Bateria se poate schimba distructiv.
                      • #41
                        Cat costa un senzor ? Doar OE se gasesc ?
