Deaia există Dialogys, problema e că uneori după VIN nu găsești piesele de pe mașină(de ex SL10 are tamburi mari ventilați dar pe VIN tamburi normali) așa că uneori întâi verifici fizic mașina apoi cauți coduri.
La plăcuțe de frână de TCe sunt 2 tipuri și vreo 5 coduri din 2012 până în prezent
Salut, ma intereseaza un cod pentru obturator / garnitura / dop de caciuc care acopera gaurile din partea de jos la portiere, pe acolo se scurge apa de ploaie care intra in portiere.
Multumesc!
The link is for Logan II ph1, Logan II ph2 has a different vehicle type, besides ph2 might has the new calipers which require different brake-pads
The vehicle type code does not differentiate after facelift, but after engine and exhaust standard.
type MA H4B400 euro 5
type M1 H4B408 euro 6b
type JR H4B408 euro 6c
Thanks a lot, this helped me regarding my matter. I also compared the two types of caliper from the image uploaded by t0rque and the ones on my car are the "big" ones, so I must buy the longer/wider pads, the code being 410605536R (confirmed after searching by VIN on the site above).
OK. First of all eastcowboy tried to help our colleague netzky with the brake pads code, without complete vehicle data or VIN. We have to appreciate his help with the link. Is very useful for all and if we have doubts on some code choice (option) we can double check.
Beside the fact that eastcowboy has a good contribution on this forum with a lot of interesting things.
Asa credeam si eu...
Am luat Lemforder (online ...sursa de incredere...) pt Logan 1.4 si au cedat undeva pe la 15-19000 km(nu-mi aduc aminte exact) -fara a da cu masina in cratere sau sa merg pe drumuri nepavate.Asfatl si protejata la maxim.Originala de fabrica (partea din dreapta)a tinut 96000 km ! Lemforderele de care vorbeam le-am inlocuit cu Ruville (deja au depasit 25000km)
Sunt multe piese contrafacute pe piata Atentie mare!
