Diagnoza Si Activari Functii Cu Clip Si DDT4ALL
Originally posted by eastcowboy View Post
I suspect it's the LPG switch (since pressing it a couple of times fixed the problem) and I already bought a replacement, but I'd like to keep a good scan tool in the car and avoid any towing fees if possible. I'll look into getting an ELM327 as well, but I'm more interested in the CAN Clip and which type to buy ("Gold" PCB with the QC chip or Green PCB with the SC chip).
Btw, is this considered a good ELM327 interface?Last edited by 77sky; 8 February 2021, 20:50.
If you want to buy an interface, pay attention to these criteria https://cvtz50.info/en/elm327/
examples
- Likes 4
How can I open the .exe file? It seems to be an archive. If I double click on it I got an error message, do I need a special program?
Merci! / Thanks!
Originally posted by emilian_rks View PostIf I double click on it I got an error message,
- Likes 1
Pentru cine doreste am urcat o baza de date pentru ddt4all din 07.2020 full (284 Mb, 3415 fisiere, mi-a luat ceva timp conversia ei) pe: https://gofile.io/d/LoLtE7
Toate cele bune!
- Likes 2
Baza ddt4all din februarie 2021(289 Mb, 3479 fisiere, cu 64 mai multe decat cea pe care am transformat-o in postul precedent), compilata de un alt user pentru care am tot respectul, toate multumirile merg catre 66GUA, pe: https://gofile.io/d/MfTp9e
Arhiva se redenumeste in ecu.zip si se pune in locatiile corespunzatoare.
- Likes 4
Originally posted by Gil26 View PostPentru cine doreste am urcat scheme electrice Logan pe: https://gofile.io/d/qXvvUz
Se citeste readme.txt, pentru Logan\SanderoII este NT8703 (2015), se dezarhiveaza si se lanseaza NT8703\ENG\HTM\ENTREE.html (se poate crea si un shortcut). Atasat cateva capturi.
In arhiva am pus si ultima versiune PyClip2.2 a lui Marianpol, toate multumirile merg catre el (si lucreaza la dezvoltarea PyRen).
Si Cedric Paille a lansat un nou release ddt4all sub Python3, mai este de lucru dar e bine ca se dezvolta in continuare.
- Likes 1
Pentru cine doreste am urcat din nou schemele electrice pe: https://gofile.io/d/NeJBws
Baza de date pentru PyRen compilata din CanClipV205, full Dacia\Renault (a durat cateva ore), am pus si arhiva pyrendata_205.zip prelucrata pentru PyClip, pe: https://gofile.io/d/ZMBuo3
- Likes 8
