Hello It is very difficult to write in Romanian, as I use Google translator. I am very glad to welcome all.
I want to increase the ground clearance on your MCV, so I need arch extenders or Aparatori Aripi. They should not be like the picture in this thread. They should be similar to this: How do Sandero Stepway. Maybe you prompt me any online shop or place where they are sold? I really need!
Sandero is increased to 175 mm in Europe and up to 185 mm in Brazil due to the tires.
This is made more long-stroke damper moves, reinforced springs and stabilizer bar.
Here's the tire mounted on the Sandero Stepvay:
195/60 R16
185/65 R15
185/70 R14
difference between 14 and 15 - 3.5 mm
difference between 14 and 16 - 12.5 mm
difference between 15 and 16 - 9 mm
Ground clearance I will add to both the Sandero Stepvay that is put to other shock absorbers and springs, and other tire 195/60 R16. I simply extensions of arches, or protection of the edge of the wing, or molding the wing or wing flaps in flight over the edge of the wing. And just as the Sandero Stepvay. Like this:
195/60 R16
185/65 R15
185/70 R14
