Am un subwoofer (Jensen Pro Audiovox Bp212) si vreau sa imi achizitionez un amplifcator!! Ma intereseaza daca ma puteti ajuta cu niste sfaturi, daca sar potrivi amplificator??
Acesta e amplificatoru
Caracteristici generale
Producator
Peiying
Clasa amplificator:
AB
Putere totala (W):2000
Putere RMS (W):200
Numar canale:2
Frecventa de raspuns (Hz):20
Lowpass (Hz):
45Hz - 300Hz
Highpass (Hz):
45Hz - 300Hz
Informatii suplimentare:
RMS Power (4 ohms): 200W
RMS Power (4 ohms) chanels: x 2
RMS Power (2 ohms): 300W
RMS Power (2 ohms) chanels: x 2
Bridged RMS Power: 500W
Bridged RMS Power chanel: x 1
Minimum Impedance Unbridged: 2 Ohm
Minimum Impedance Bridged: 2 Ohm
Frequency response: 20Hz
Impedance imput: 15k Ohm
Fan Cooled: No
Signal to Noise Ratio: 90dB
Channel Separation: 50dB
THD: 0.08%
IMD: 0.08%
Remote bass boost control: 0.2V - +6V
High-Pass filter: 45Hz - 300Hz
Bass Boost: 0dB - +12dB
Low-Pass filter: 45Hz - 300Hz
Fuse Rating: 25Ax3
Depth: 470mm
Height: 250mm
Width: 56mm
Dimensiuni (L x l x i mm):
250 x 470 x 56
Greutate (Kg):5.25
Acesta subwooferu
Product Type Woofer
Manufacturer Part Number BP212
Manufacturer Website Address Welcome to Audiovox Corporation
Manufacturer Audiovox Corporation
Product Model BP212
Product Name Jensen BP212 Bandpass Speaker System
Brand Name Audiovox
Speaker Diameter 12"
Impedance 8 Ohm
RMS Output Power 400 W
PMPO Output Power 1.20 kW
Tech Specs
Product Type Woofer
Product Model BP212
Brand Name Audiovox
Additional Information
Switchable Red/Blue LED Illumination
Nickel Plated Push-In Terminal Block
Quad Aero Port Design for Deeper Bass
Dual 4th Order Bandpass Subwoofer System
Carpeted Enclosure
Plexiglass Viewing Window
Computer Tuned Acoustic Chambers
MDF Construction
2 Chamber Design
Low-Q Optimized Driver
No Crossover Needed for Simple Installation
Easy Add-on for Existing Systems
Impedance 8 Ohm
Producator
Peiying
Clasa amplificator:
AB
Putere RMS (W):200
Numar canale:2
Lowpass (Hz):
45Hz - 300Hz
Highpass (Hz):
45Hz - 300Hz
Fan Cooled: No
THD: 0.08%
IMD: 0.08%
Fuse Rating: 25Ax3
Depth: 470mm
Height: 250mm
Width: 56mm
250 x 470 x 56
Greutate (Kg):5.25
Acesta subwooferu
Product Type Woofer
Product Model BP212
Brand Name Audiovox
Impedance 8 Ohm
Tech Specs
Product Type Woofer
Product Model BP212
Brand Name Audiovox
Carpeted Enclosure
MDF Construction
2 Chamber Design
Impedance 8 Ohm
