IF-37-DOC Honda CRX DelSol By Dimsport
  • #31
    sal doc am si eu o intrebare:
    cam ce consum are masina ??
    LogAnClub "Andrei" B-86-KAWsigpic
    • #32
      Un test de consum facut la pompa mi-a indicat un consum intre 8-9% numai oras, 6.3% in afara orasului si 8.2% condus in forta (ture mari) extraurban.
      • #33
        bafta cu proiectul!
        cand e gata poate dai o tura pe la polivalenta cu ea
        http://www.loganclub.ro/forum/loganu...am-t11058.html
        • #34
          O sa dureze ceva pana va fi gata.
          • #35
            ai bagat polizorul la vopsit??
            The MVP
            • #36
              Inca nu. S-ar putea sa vin cu el maine la gratar, decapotat. ;)
              • #37
                Polizorul inca nu a intrat la vopsit ;( insa lista de consumbile pe care trebuie sa le schimb la masina s-a marit un pic.
                Momentan cutia cu surprize contine ulei Motul 300V 5W30, lichid de frana Motul RBF660, buji NGK Iridium, fise, condensator si capac delco Vision, curea si rola distributie Honda OEM, pompa de apa Honda OEM. Restul de piese Honda OEM astept sa sosesca din US si arata cam asa:
                72320-SR2-043 WEATHERSTRIP, FR. PILLAR
                72330-SR2-033 WEATHERSTRIP, RR. PILLAR
                72410-SR2-003 MOLDING, R. DOOR
                74306-SR2-003ZG MOLDING ASSY., R. FR. ROOF
                74316-SR2-003ZG MOLDING ASSY., L. FR. ROOF
                91525-SR2-013 CLIP, DOOR MOLDING
                91567-SR2-013 CLIP
                93903-240G0 SCREW, TAPPING (4X6)
                91653-SR2-003 GROMMET, SCREW (4MM)
                85141-SR2-033 WEATHERSTRIP, R. ROOF SIDE
                85191-SR2-033 WEATHERSTRIP, L. ROOF SIDE
                90148-SR2-000 SCREW, TRUSS (4X8)
                85220-SR2-020 GUIDE, ROOF LOCK
                85225-SR2-902 GUIDE, R. FR. ROOF STOPPER
                73152-SR2-003 MOLDING ASSY., R. FR. WINDSHIELD SIDE
                73162-SR2-003 MOLDING ASSY., L. FR. WINDSHIELD SIDE
                73151-SR2-013 MOLDING, FR. WINDSHIELD (UPPER)
                91511-SR3-003 CLIP D, FR. WINDSHIELD SIDE MOLDING (ORANGE)
                91518-SR2-003 CLIP A, FR. WINDSHIELD SIDE MOLDING (NATURAL)
                12341-PR3-000 GASKET, CYLINDER HEAD COVER
                14775-PR3-000 SEAT, VALVE SPRING
                77350-SR2-A00ZB COVER ASSY., COLUMN (UPPER)
                80411-SR2-003 KNOB, AIR CONDITIONER SWITCH
                54107-SA0-010 BUSH, RR. JOINT
                54110-SH3-003 SEAT, CHANGE LEVER BALL
                51220-S04-003 JOINT, BALL (LOWER) (MUSASHI)
                51455-SR3-004 BUSH, FR. ARM (UPPER) (SUMITOMO)
                51392-SR3-024 BUSH, FR. ARM (LOWER)
                90175-SH3-005 BOLT, SHOCK ABSORBER FORK
                51306-ST7-000 BUSH, STABILIZER HOLDER
                51312-SR3-000 RUBBER, STABILIZER END
                51398-SR3-000 WASHER B, FR. RADIUS ARM (14MM)
                51399-SR3-010 WASHER A, FR. RADIUS ARM (18MM)
                51810-SH3-004 BUSH, SHOCK ABSORBER (YAMASHITA)
                51395-SR3-N03 BUSH, R. FR. COMPLIANCE (YAMASHITA)
                51396-SR3-N03 BUSH, L. FR. COMPLIANCE (YAMASHITA)
                44017-SR3-000 BOOT SET, INBOARD
                44018-SR3-C03 BOOT SET, OUTBOARD (SUPERCEDED)
                74766-SR2-950 COVER, ROOF HOLDER STRIKER
                74815-SK7-000 GROMMET, KEY CYLINDER
                91510-SM4-003ZH CLIP, TRUNK LID STOPPER
                De abia astept sa schimb piesele din lista de mai sus, e ca si cum as face masina noua.
                • #38
                  mama docule da ai comandat ceva piese, o sa o faci nou nouta !!!!!
                  The MVP
                  • #39
                    Pai nu aveam de ales. La varsta ei cam toate gumele erau ramolite.
                    • #40
                      ia spune nea Doc , ce mai e nou pe aici ??
                      • #41
                        In afara de faptul ca masina se afla la o cura de bronzare in parcare, in rest n-am nimic nou de spus despre ea. Am comandat cateva piese din US si astept sa vina. Ultimul drum pe care l-am facut la Sibiu a distrus placa de presiune, asa ca acum trebuie sa astept kitul de ambreiaj si volanta.
                        Va este dor de ea? As fi vrut sa vin si eu la Alexeni insa au inceput concursurile de MTB si aproape in fiecare weekend am de facut trasee montane sau antrenamente cu bicicleta. Ma lupt cu greutatea, trebuie sa dau jos tot ce s-a adunat asta iarna, momentan am ajuns la 80kg.
                        Modificarile la aceasta masina le voi face lent, in functie de buget si timp.
                        • #42
                          e bine ca faci sport si ai cu ce si cu cine.
                          astept sa`ti vad realizarile la masina asta , te stiu pasionat si o sa scoti cei bun din ea.
                          sti ca mai ai abonat la o tura cu masina cand o faci
                          numai bine
                          • #43
                            Sunt pasionat de prea multe lucruri si asta e un defect pentru ca nu ma pot ocupa numai de unul singur. Le incep pe toate si le finalizez greu.
                            • #44
                              frumoasa masinutza cu un foarte mare aspect de sportivitate bafta in continuare
                              • #45
                                Trebuie sa ii fac poze...in curand nu o sa mai gasesc prin iarba. A crescut buruiana pe langa ea de atata stat. Mi-au venit toate piesele comandata, am facut depozit in garaj. Urmeaza cat mai curand sa le pun pe masina si sa o scot la plimbare.
