cu logan mergi toata autostrada 200 dus-intors daca tii musai, deci nu inteleg despre ce vorbim aici. aa, si un clio cu spatiu de matiz tu il compari cu Logan?
					Prestige 16v
 Am primit raspunsul de la Valeo. Inca odata departamentul lor de ralatii cu clientii functioneaza ireprosabil. Tot respectul pentru ei.
 Iata ce au raspuns :
 mail trimis de mine
 I have a problem reguarding the Valeo CSC that i fitted on my Dacia Logan 1.6 16v.
 The part numbers are: clutch kit Valeo 826853, CSC Valeo 804527. The parts are brand new and original.
 The problem. In the morning, when the engine is cold, i start it up and something starts squeaking. When i press the chutch pedal just 2 or 3 milimeters it goes away. When in take my foot of the pedal it starts squeaking again.
 It goes like that for 1 or 2 minutes and then it is perfectly silent all day long in all driving conditions. It squeaks only when the engine/clutch it' cold.
 I read that this is a very common problem in a lot of cars but i did not find what causes this.
 Heare are two videos with the squeak http://www.youtube.com/watch?v=7oolAbfEatg and http://www.youtube.com/watch?v=23tRR...feature=relmfu
 Can you please help me solve this problem ? I am waiting for your response.
 Thank your for your understanding.
 Raspuns
 Hi,
 The pedal noise can be generated from a number of issues.
 If there is an issue with the master cylinder and the bearing is not loaded enough on the clutch cover, the CSC will 'skid' on fingers.
 Also, there could be air inside the hydraulics causing the bearing to no be loaded correctly and only when warm does this issue disappear.
 There could be an issue with the thrust bearing on the CSC but this noise will be present at all times.
 Until the parts fitted are checked and the other parts of the clutch release system are checked, the cause of the noise cannot be confirmed.
 Regards,
 Greg
 Avem viteza citita din ABS.
 Se trage un fir din ECU ABS intr-o mufa din cutia cu sigurante de la motor si se scoate mufa din cititorul de pe cutie.
 Eroare kilometrajului este fix 0 zero.
 Ii multumesc de o mie de ori colegului Fane ( Calarasi )
 Zgomotul rulmentului la pornirea rece dimineata, s-a diminuat foarte mult. La un simplu spritz al pedalei de ambreiaj tace.
 Singura explicatie pe care mi-o dau ar fi ca discul de MCV 16v este cu aproape 1mm mai gros decat discul normal si a bagat soarele placii de presiune mai inauntru spre volanta.
 In acest fel degetele placii nu apasau suficient pe rulment si acesta patina pe soare.
 Cand se va roda complet discul zgomotul ar trebui sa dispara definitiv.
 In filmulet se pleaca cu treapta 1
 Logan + cutie viteze de SuperNova
