vand scaune fata pasat cu incalzire pretul este de 300ron.
Bazarul din MIOVENI
VAND TELEFON SAMSUNG GALAXY S PLUS 8 GB, CAMERA VIDEO DE 5 MP+VGA, ANDROID. NU ESTE BLOCAT IN NICI O RETEA
PRET 950RON
•General: GSM 850/900/1800/1900 MHz, UMTS 900/1900/2100 MHz, HSDPA 14.4 Mbps, HSUPA 5.76 Mbps
•Form factor: Touchscreen bar phone
•Dimensions: 122.4 x 64.2 x 9.9 mm, 119 g
•Display: 4.0" 16M-color WVGA (480 x 800 pixels) SuperAMOLED capacitive touchscreen, Gorilla Glass
•CPU: 1.4 GHz Scorpion processor, Qualcomm MSM8255T Snapdragon
•GPU: Adreno 205 GPU
•RAM: 512 MB
•OS: Android 2.3.3 (Gingerbread)
•Memory: 8 GB storage, microSD card slot (up to 32 GB)
•Camera: 5 megapixel auto-focus camera with face and smile detection, touch focus; HD (720p) video recording at 30fps, front-facing VGA camera, video calls
•Connectivity: Wi-Fi b/g/n, Wi-Fi hotspot, Bluetooth 3.0+HS, standard microUSB port,
•GPS receiver with A-GPS, 3.5mm audio jack, FM radio, TV out
•Misc: TouchWiz 3.0 UI, DivX/XviD codec support, built-in accelerometer, multi-touch input, proximity sensor, Swype text inputNimeni nu e destul de inteligent ca sa poata convinge pe un prost ca e
prost.
VAND Samsung C5212 Dual Sim - 350RONAttached FilesNimeni nu e destul de inteligent ca sa poata convinge pe un prost ca e
prost.
Vand piesa auto logan originale si aftermarket
Bujii logan diesel 1.5 diesel.........................................35l ei/buc
Bujii logan benzina 1.4/1.6.........................................55 lei/set
Kit distributie logan 1.5 diesel.....................................280lei/set
Kit distributie logan 1.4/1.6 benzina.............................180lei/set
Brat logan echipat........................................... .........90 lei/buc
Rulment fata cu sau fara abs......................................90 le/buc
Placute fata logan............................................. .......60lei/set
Placute frana logan van originale dacia pe fata...............90lei/buc
Bucsa bara stabilizatoare.................................... ........15lei/buc
Bieleta antiruliu logan............................................. ....25lei/buc
Bieleta directie logan............................................. .....100lei/buc
Capete de bara logan originale dacia.............................100lei/buc
Senzor/sonda servodirectie..................................... ....60 lei/buc
Senzor abs original logan............................................8 0lei/buc
Furtun turbina original de logan (cel in forma de S)..........250 lei/buc
Radiator intercooler original logan 1.5 dci.......................280 lei/buc
Bloc lumini cu proiector original logan............................150lei/buc
Suport motor original logan 1.5 dci (hidroelastic).............150lei/buc
Fulie ax cu came logan origine dacia 1.5 dci diesel...........120lei/buc
Motoras inchidere centralizata originala dacia logan..........25lei/buc
Bobina inductie logan originala 1.4/1.6 benzina................190lei/buc
Garnitura chiuloasa logan 1.5 diesel...............................70lei/buc
Garnitura chiuloasa logan 1.4/1.6 benzina.......................60lei/buc
Toate produsele sunt origine renault
Aducem orice piesa de logan originale si aftermarket
Persoana de contact Silviu Sandulescu 0747394360Attached Files- bobina-inductie-logan-originala-1-4-1-6-benzina-65ce1fd4a1f865d1c-96-72-1-95-1.jpg (1.8 KB, 451 views)
- bucsa-bara-stabilizatoare-original-dacia-a6044fc751485739e-96-72-1-95-1.jpg (1.4 KB, 452 views)
- fulie-ax-cu-came-logan-origine-dacia-1-5-dci-fe94afd49ee0ec8fd-96-72-1-95-1.jpg (1.6 KB, 456 views)
- garnitura-chiuloasa-logan-originala-1-5-diesel-f4293fd154988b6ac-96-72-1-95-1.jpg (2.2 KB, 451 views)
- motoras-inchidere-centralizata-originala-dacia-aa669fd3eb803aab4-96-72-1-95-1.jpg (2.1 KB, 450 views)
- vand-rulment-fata-logan-cu-si-fara-abs-marca-snr-6694cfd4b40853888-96-72-1-95-1.jpg (1.6 KB, 459 views)
- bieleta-antiruliu-logan-original-dacia-99658fc735f0375a0-96-72-1-95-1.jpg (1.7 KB, 454 views)
- bieleta-directie-logan-originale-dacia-8b2b5fc6f2a8944ad-96-72-1-95-1.jpg (1.9 KB, 455 views)
- bloc-lumini-cu-proiector-original-logan-50fb7fd3e2e0d38c0-96-72-1-95-1.jpg (1.2 KB, 454 views)
- capete-de-bara-logan-originale-dacia-5b2a0fc6e4f0d61db-96-72-1-95-1.jpg (1.9 KB, 457 views)
- furtun-turbina-original-de-logan-cel-in-forma-de-s-56c1ffd387e012c6a-96-72-1-95-1.jpg (2.5 KB, 453 views)
- kit-distributie-logan-1-5-diesel-original-dacia-d1667fcc63e8c0144-96-72-1-95-1.jpg (2.1 KB, 451 views)
- placute-frana-logan-van-originale-dacia-41792fd15760f0ab1-96-72-1-95-1.jpg (1.9 KB, 458 views)
- radiator-intercooler-original-logan-1-5-dci-3ec6afd3cc60f72f1-96-72-1-95-1.jpg (1.9 KB, 454 views)
- senzor-abs-original-logan-97018fd39348c723f-96-72-1-95-1.jpg (1.9 KB, 456 views)
- senzor-servodirectie-original-logan-9f45cfd4e0206d705-96-72-1-95-1.jpg (1.1 KB, 459 views)
- suport-motor-original-logan-1-5-dci-hidroelastic-bddc9fd3ac08d1785-96-72-1-95-1.jpg (1.8 KB, 458 views)
- bujii-logan-1-5-diesel-originale-e0323fc0098074172-96-72-1-95-1.jpg (1.7 KB, 452 views)
- bujii-logan-set-4-buc-1-4-1-6-originale-dacia-cu-63252fd4a62857972-96-72-1-95-1.jpg (2.0 KB, 454 views)
Vand Lapsto Acer aspire 5738ZG
Aspect: 10/10 Functionalitate: 10/10
-Se prezinta ca nou,arata si functioneaza perfect.Bateria tine peste 2 ore(a fost folosita extrem de putin,si a stat scoasa din laptop)
-Vine in cutia originala cu toate accesoriile.
Configuratie:
Procesor - IntelĀ® PentiumĀ® Dual Core
Tehnologie procesor:45 nm
Model procesor:T4200
Frecventa procesor:2000 MHz
FSB:800 MHz
Cache:1024 KB
Display
Rezolutie:1366 x 768
Diagonala:15.6 inch
Tehnologie display:LED
Memorie
Capacitate memorie:4 GB
Tip memorie DDR3
Frecventa:1066 MHz
Hard Disk
Capacitate Hard Disk:500 GB
Viteza: 5400 rpm
Placa Video
Tip memorie videoedicata
Capacitate memorie video:512 MB
Producator chipset video:Nvidia
Model:Geforge G105M
Multimedia
Unitati citire/scriere DVD RW
Audio:
Difuzoare stereo
Cititor de carduri
Camera WEB:0.3 MP
Porturi
HDMI:1
Microfon:1
USB 2.0:4
Iesire audio:2
VGA:1
RJ-45:1
Comunicatii
Retea:10/100
Wireless:802.11 b/g/n
Alimentare
Baterie:Li Ion 6 Celule
Autonomie de lucru:Pana la 3 ore
Altele
Greutate:2.8 Kg
Dimensiuni (W x D x H):383 x 250 x 26 - 37 mm
Tastatura numerica
Pretul este de 1200ron
Vand Samsung Galaxy S I9000 8gb
Aspect 9 / 10 (urme de folosire pe capacul din spate...ecranul este ca nou , are folie pe el)
Functionalitate 10 /10
Bateria tine in jur de 2 zile,folosire normale.
Vine insotit de incarcator.
Pret 800ron
Contact :
ID: chelull (chelull@yahoo.com)
Tel: 0767240115Viteza Ucide ... Conduceti cu prudenta !!!
Originally posted by ssandulescu View PostBujii logan diesel 1.5 diesel.........................................35l ei/buc
SCHIMBURI ULEI:
- filtru ulei original.............15 lei
- filtru aer original.............20 lei
- filtru polen man..............56 lei
- ulei dacia oil 10w40/4l.....76 lei
- ulei dacia oil 5w30/4l.......90 lei
- filtru ulei aftermaket........9 lei
- filtru aer aftermaket.........15 lei
- ulei 10w40/4l...................69 lei
KITURI DE DISTRIBUTIE:
- kit distributie 1.4/1.6 original.......180 lei
- kit distributie 1.4/1.6 gates..........150 lei
- kit distributie 1.4/1.6 contitech.....120 lei
- kit distributie 1.5 original.............300 lei
- kit distributie 1.5 contitech...........250 lei
- kit distributie 1.5 flennor..............200 lei
APRINDERE SCANTEIE/INCANDESCENTA
- bujii benzina 1.4/1.6 original....................15 lei/buc
- bujii diesel 1.5 original.............................35 lei/buc
- fise buji aftermarket.................................37 lei/set
- platou carbuni aftermaket..........................45 lei
- bobina inductie aftermaket.........................100 lei
- bloc lumini cu proiector original...................150 lei
DIRECTIE/SUSPENSIE/ROTI
- janta logan tabla aftermarket......................145 lei/buc
- rulment fata cu abs original.........................100 lei
- rulment fata fara abs original.......................90 lei
- cap de bara original....................................100 lei
- bieleta directie original................................100 lei
- bieleta antirului original...............................30 lei
- bucsi bara stabilizatoare original ..................15 lei
- brat echipat stg/dr original...........................90 lei
- caseta de directie mecanica aftermarket......320 lei
- planetare originale.....................................750 lei/set
SISTEMUL DE FRANARE
- placute frana originale.................................60 lei
- placute frana logan van originale..................90 lei
- senzor abs original......................................80 lei
- senzor/sonda servodirectie originala.............60 lei
MOTOR
- fulie ax came original...................................120 lei
- garnitura chiuloasa diesel 1.5 originala...........70 lei
- garnitura chiuloasa benzina 1.4/1.6 originala...60 lei
- furtun turbo cel in forma de S original.............250 lei
- suport motor original.....................................150 lei
SISTEMUL DE RACIRE MOTOR:
- radiator apa 1.5 fara ac aftermarket...............180 lei
- radiator apa 1.4/1.6 fara ac aftermarket.........138 lei
- radiator intercooler original............................280 lei
- pompa de apa aftermerket.............................100 lei
ELEMENTE TUNING/COROSERIE
- faruri angel eyes set 2 buc............................350 lei
- stopuri tuning pentru logan 2 buc...................180 lei
- cotiera logan clasica.....................................80 lei
- pachet alarma+inchidere centralizata.............170 lei
- bare porbagaj logan ....................................180 lei/set
- huse scaune logan diverse culori...................90 lei/set
- faruri logan facelift.......................................180 lei/buc
- lampa spate completa...................................80 lei
- Faruri angel-eyes + Stopuri tuning pentru Logan..........440lei/set
ADUCEM ORICE PIESA DE LOGAN SI DIN GAMA RENAULT
Tel: 0747.394.360
Mail: sandulescu.silviu@yahoo.com
Disponibil oricand
Transport gratuit in Pitesti, iar in tara prin curierat rapit sau posta romana la alegerea clientului plata rambursAttached Files- bujii-logan-1-5-diesel-originale-e0323fc0098074172-96-72-1-95-1.jpg (1.7 KB, 309 views)
- bieleta-directie-logan-originale-dacia-8b2b5fc6f2a8944ad-96-72-1-95-1.jpg (1.9 KB, 309 views)
- bieleta-antiruliu-logan-original-dacia-99658fc735f0375a0-96-72-1-95-1.jpg (1.7 KB, 305 views)
- capete-de-bara-logan-originale-dacia-5b2a0fc6e4f0d61db-96-72-1-95-1.jpg (1.9 KB, 310 views)
- cotiera-logan-clasic-mcv-si-van-65372faaab3062b4d-96-72-1-95-1.jpg (1.6 KB, 311 views)
- faruri-angel-eyes-stopuri-tuning-pentru-logan-badedfe130b80aedd-96-72-1-95-1.jpg (2.0 KB, 307 views)
- furtun-turbina-original-de-logan-cel-in-forma-de-s-56c1ffd387e012c6a-96-72-1-95-1.jpg (2.5 KB, 313 views)
- lampi-spate-logan-clasic-mcv-si-facelift-87f3afa98910563c8-96-72-1-95-1.jpg (1.8 KB, 312 views)
- set-huse-scaun-confort-32acafa9dca0bda61-96-72-1-95-1.jpg (2.2 KB, 311 views)
- senzor-sonda-servodirectie-original-logan-9f45cfd4e0206d705-96-72-1-95-1.jpg (1.1 KB, 314 views)
Salut. nu stiti pe nimeni care sa vanda jante aliaj originale ph2 sau model Bran.
ofer 200 euro doar pt jante in stare impecabila+prezoane+capaceAttached Filesfara
Configuratie:
FSB:800 MHz
Cache:1024 KB
Display
Diagonala:15.6 inch
Memorie
Tip memorie DDR3
Frecventa:1066 MHz
Hard Disk
Viteza: 5400 rpm
Placa Video
Model:Geforge G105M
Multimedia
Audio:
Difuzoare stereo
Cititor de carduri
Camera WEB:0.3 MP
Porturi
HDMI:1
Microfon:1
USB 2.0:4
Iesire audio:2
VGA:1
RJ-45:1
Comunicatii
Retea:10/100
Alimentare
Altele
Greutate:2.8 Kg
Tastatura numerica
Pret 800ron
Contact :
vand volan ph2 imbracat in piele, cu tot cu airbag, pret 300 ron fix.
si un bidon de 4L de ulei MOBIL SUPER 3000, full sintetic, 5w40 la 100 ron
