Bazar Pitesti
  • numa televizor olimp H2 sau venus.dar tre sa gasesti lampi pl.scuze de off da nu m-am putut abtine.
    [img]http://www.loganclub.ro/forum/attachment.php?attachmentid=417003&d=1355899108[img]
    • ma ce rau esti fitz-ar lampile. tu ti-ai pus d-alea rusesti ca prea luminezi bine
      • Cumpar alarma auto ieftina.
        • Originally posted by Champion View Post
          Vand monitor SAMSUNG SyncMaster 793df 17inch aproape nou [ATTACH]286243[/ATTACH]
          Diagonala :17
          Rezolutie optima :1024x768 / 85 Hz
          Tip tub : DynaFlat
          Dimensiune punct (mm) :0.20
          Rata verticala de refresh (Hz) :50-160
          Rata orizontala de refresh (KHz):30-70
          Rezolutii suportate Maximum 1280x1024 / 65 Hz
          Standarde: MPR-II
          Display
          Semnal intrare: 15-pini d-Sub,Separate H/V
          Putere consumata (W): 80
          Pret 2mil negociabil
          • vand suport ochelari logan(este nou.,ambalat in folie cu emblema piesa de origine)...am doar 2 buc...pret 23 ron bucata
            prefer predare personala..numai in pitesti
            sigpicmasina personala pare cea mai deosebita
            • Vand monitor SAMSUNG SyncMaster 793df 17inch aproape nou Atasament 286243
              Diagonala :17
              Tip tub : DynaFlat
              Standarde: MPR-II
              Display
              • - GeForce Gainward 6600GT - 128Mb / AGP - 50 lei
                - aparat foto Fuji S5800 + accesorii (filtre, parasolar, inel step-up) - 620 lei
                - Hifonics ZEUS POWER BASS PACK (woofer + amplificator + cablaj) - 1800 lei
                - Sistem AMD - Procesor AMD Quad-Core 9500, placa baza Gigabyte GA-M56S, 4Gb RAM DDR2, 2 x 500 Gb HDD, GeForce 9800 GT 512 Mb, DVD RW, Card reader, sursa Spire, carcasa RAIDMAX Sagitta 2 Black - 1550 lei
                - Monitor LG 22" , gri, DVI + VGA, Rezolutie 1920 x 1080 pixeli - pret 600 lei
                - 2 seturi leduri tetiere + 2 neoane albastre + un neon mov = 80 lei
                - HDD Seagate, SATA-II, 500GB - 200 lei
                - schimb capota cu priza activa si badboy cu model stock + diferenta
                • Originally posted by alexutzu View Post
                  @hmv...consola aia daca o mai gasesti pe undeva mai jos de 80-100 de lei nu o s gasesti
                  uite ca gasesti
                  -aparatori fata+spate logan 60 ron setul (30 ron fata/spate)
                  -maciulie ph1 20 ron (in stare foarte buna
                  -actuator 30 ron
                  -cuie usi ph2 40 ron (4 buc)
                  -contactor portbagaj 10 ron
                  -capacel janta aliaj 15 ron
                  -suport butoane geamuri electrice spate 10 ron
                  -tunel de sub maneta de viteza ph1 20 ron
                  -carcase chei supernova/solenza cu buton 35 ron
                  -lampa torpedou/portbagaj (fara intrerupator) 20 ron
                  -faruri ph2 450 ron setul
                  -4 injectoare noi renault 1,9dci (se poate vedea codul de reper in poza) -10 mil
                  -plafoniera logan noua cu 1 bec 30 ron
                  -plafoniera logan noua cu 3 becuri 50 ron
                  -sonda marsarrier LOGAN 60 ron
                  -contactor pedala frana LOGAN DCI 35 ron
                  -joistick oglinzi electrice 40 ron
                  -contactori usa 10 ron
                  -cablaj proiectoare ph1 (cablaj Y) 45 ron
                  -suporti proiectoare bara mcv ph1 65 ron
                  -grila bara mcv ph1 55 ron
                  -maciulie logan ph2 negra 35 ron
                  -maciulie logan prestige 50 ron (fara piele)
                  -maciulie logan prestige 70 ron (din piele)
                  -comanda ventilatie logan ph1 70 ron
                  -comanda ventilatie logan ph2 100 ron
                  -comanda volan audio (duster, black line) 75 ron
                  -consola centrala gri logan ph1 50 ron
                  -inele aeratoare negre originale 35 ron/setul
                  -inele aeratoare albastre –30 ron/setul
                  -inele aeratoare gri –30 ron/setul
                  -ornament negru tija deschidere/inchidere panou logan ph2 – 20 ron setul(4 buc)
                  -buton blocare/deblocare usi ph2 - 20 ron
                  -buton dezaburire luneta ph2 - 20 ron
                  -butoane geamuri spate logan (cu suport) - 50 ron/2buc.
                  -geam oglinda ph1 cu incalzire (st+dr) 25 ron/buc
                  -bujii incandescente beru logan diesel (originale) 120ron
                  -bujii logan/dsn/solenza eyquem (1 electrod) 50 ron
                  -bobina inductie 100 ron
                  -cablu acceleratie 50 ron
                  -butoane geamuri solenza/logan spate(cu tot cu suport) 50 ron
                  -fise bujii beru originale 85 ron
                  -buton avarie solenza nou (sigilat) 45 ron
                  -opritor usa logan 50 ron
                  -oglinzi electrice incalzite ph1 150 ron setul (negociabil)
                  -oglinzi electrice incalzite noi ph2 350 ron setul (culoarea capacului la alegere)
                  -carenaje scaun gri deschis ph1 30 ron/setul
                  -carenaje scaune gri ph2 40 ron/setul
                  -manere panou ph2 90 ron/setul
                  -manson schimbator original 40 ron
                  -clapeta deschidere usa ph2 (gri) - 15 ron bucata
                  -curea distributie logan MPI de origine (cu rola) 220 ron
                  -pompa apa logan MPI de origine 240 ron
                  -diferite componente ale ceasurilor de bord
                  -manere complete panou ph2 (manere+baghete) 120 ron/setul
                  -ceasuri bord logan/duster/sandero - 140 ron (cb) (0 km la bord) (se poate adauga si geamul pt. 30 ron)
                  -ceasuri bord logan prestige - 170 ron (cb) (0 km la bord) (se poate adauga si geamul pt. 30 ron)
                  -maciulie piele + mason schimbator - 100 ron
                  -autocolant stalpi - 50 ron setul (4 buc.)
                  -buton avarie logan - 35 ron
                  -actuatoar usa logan - 35 ron/buc (120 ron setul 4buc)
                  -sonda servodirectie logan - 60 ron
                  -aparatori aripi logan - 65 ron setul (fata+spate)
                  -cochilie volan ph1 (completa) - 60 ron
                  SERIGRAFIE DUSTER MPI/DCI - 65 RON (FARA ACE)
                  SERIGRAFIE ALBA - 65 RON (FARA ACE)
                  INELE BORD PRESTIGE - 50 RON
                  INELE BORD LAUREATE - 35 RON
                  INELE BORD DUSTER - 50 RON
                  ECRAN NEGATIV - 50 RON
                  GEAM CEASURI BORD NOU - 40 RON
                  • Vand
                    -autocolant stalpi imitatie carbon negru sau gri- 55 ron setul (4 buc.)-Montajul 10 ron in Pitesti
                    -ornamente clapeti interior si exterior imitatie carbon negru sau gri 10 ron/set
                    -Colez consola climatizare Logan Ph1 -45Ron (inclus materialul imitatie carbon negru sau gri)
                    -Prelungire bara cauciuc 60Ron
                    Poze in albumul meu
                    telefon:0742060266
                    • -difuzor bara spate ph1 80 lei
                      -fise bujii 80 ron set
                      -aparatori aripi 60 ron
                      -maciulie prestige 40 ron
                      -colant stalpi prestige 50 ron
                      -maneta stergatoare cu buton cb.70 lei
                      -senzor temperatura 70 lei.
                      -aparatiri noroi set 4 bucati plus aeratoare 50 ron set
                      -etrieri de van 170 lei setul
                      -triple spate cu leduri 370 ron noi
                      -grila bara mcv 50 ron
                      -suporti proiectoare mcv 55 ron setul
                      -placute de van 110 lei setul.
                      -eleron luneta 110 ron
                      -pompa servo 280 ron.
                      -planetare benzina 800 ron setul.
                      -bielete directie si capete bara cu burduf. set toate 4. 350 lei.noi.
                      -placute de origine 90 lei.noi.
                      -fagure bara ph1 plus deflector 40 lei
                      -plafoniera cu 3 becuri 35 lei
                      -etrieri normali noi la 80lei amandoi.
                      -pompa apa 170 lei.
                      -bieleta antibalans 90 lei de origine
                      -bielete antiruliu 70 lei setul.
                      -suport cv 110 lei buc
                      -bascule 120 lei .de origine.
                      -ploape far 25 lei setul.
                      -oglinzi prestige 340 lei noi pe culoare la comanda.
                      -camera video .100 lei.
                      -becuri leduri pentru pozitii,semnalizare,plafoniera,suport numar 15 lei.
                      - incalzitor bujii dci 70 lei.
                      -cheie cu baterie si cip 40 lei.
                      -reparatie injectoare delphi 180 lei buc.
                      -supape 1,4.1,6 190 lei setul.
                      -maciulie piele.55 lei
                      -prelungire bara sandero .60 lei
                      -ambreiaj complet. placa, disc, rulment, 390 lei.
                      -inele aeratoare plastic .rosi,albastre argintii..20lei setul.
                      -contactot frana.40 lei.
                      -suporti proiectoare la 30 lei.
                      -cablaj proiectoare la 40 lei.
                      -senzor turatie 65 lei.
                      .-garnitura chiuloasa 60 lei.
                      -termostat dci 1oo lei.
                      .-rola accesorii 55 lei
                      -intanzator pentru ac.150 lei.
                      -bixenon la 250 lei.....nou
                      -prelungire bord ph2 40 lei.
                      -Folie omologata LUMMAR..300 lei.cu montaj cu tot.doar in Pitesti.
                      -macarale geamuri electrice fata 300 lei setul
                      -bloc lumini cu proiectoare.plus comanda stergatoare cu ci.160 lei.
                      -toba finala mare 290 lei.
                      -toba finala mica 180 lei.
                      -antena cb ml 145 .600w .120 lei.
                      -opritor usa 40 lei nou.
                      -contactori usi.25 lei buc.noi.
                      -bucsi bara stabilizatoare.40 lei setul.noi.
                      -distributie 1,4 1,6 150 lei.
                      -sonda mers inapoi 50 lei.
                      -filtru ulei benzina 25 lei original.
                      -bujii NGK 65 lei setul.
                      -bujii EQM cu 2 electrozi.70 lei setul.
                      -pompa servo electrica 1.000 lei.originala noua.
                      -supape logan 1,4.180 lei setul.
                      -scaune supape 1,4.90 lei.
                      -semeringuri 1,4. 80 lei.
                      -flansa amortizor 50 lei.
                      rulment amortizor 35 lei.
                      -Resoftari diesel 180 lei
                      benzina 130 lei.
                      -Schimbat lumini bord,clima,butoane,plafoniera,activare sprit la stergatoare.mai multe..preturi neg.
                      relatii la tel; 0764700304 sau id ul de mess . florin_dnf
                      sigpic!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                      • Vand telefon NOKIA E90, unic proprietar, GPS incorporat, fara a utiliza coexiune internet, poate fi utilizat ca si router wireless pe o distanta de 20 metri, camera de 3.2 mp, card memorie, pachet complet, pret 800 ron neg. tel 0768471313, sau PM
                        http://www.loganclub.ro/forum/b_83_d...uy-t30810.html
                        • Vand 600grame vopsea rosu passion pentru logan, pe baza de diluant, necesita lacuire.
                          Pret 70lei.
                          La policolor costa 20lei 100grame iar cutia de 1kg costa 164lei.
                          AG 16 Y M A
                          • alin ma intereseaza vopseaua vorbim maine
                            Diverse accesorii Logan-oglinzi logan(orice model)
                            Pasla fonomin pentru antifonare 6ron mp
                            Piese/consumabile/accesorii-orice logan/dacia
                              Diagonala :17
                              Tip tub : DynaFlat
                              Standarde: MPR-II
                              Display
                              • Comment
