Salut as dori putin ajutor pentru un proiect un portbagaj de logan normal
Deci difuzoarele ar fii astea : fara link-uri externe
Specificatiile tehnice (in caz ca nu merge linku)
Noua serie de subwoofere Seria V au conul din fibra de kevlar si cos ( sasiu ) din otel .
Structura cu magnet greu (solid) si aluminiu negru permite o racire excelenta a bobinei , dand subwooferului performante excelente , concretizate intr- un sunet curat fara distorsiuni !
Specificatii tehnice
BL series 18.18 TM / parallel 8.586 TM
Fs series 30.7 Hz / parallel 30.9 Hz
Impedance series 8 Ohm / parallel 2 Ohm
Magnet weight 80 oz
Mms 146 g
Mounting depth 152 mm
Mounting diameter 273 mm
Nominal impedance 2 x 4 Ohm
Power handling (RMS/Peak) 350/700 W
Qes series 0.616 / parallel 0.664
Qms series 5.456 / parallel 5.676
Qts series 0.553 / parallel 0.595
Re series 6.4 Ohm / parallel 1.6 Ohm
Size 322mm ( 12" )
SPL (1W/m) 87.6 dB
Vas series 65.4 L / parallel 67.2 L
Voice Coil diameter 51 mm ( 2" )
Voice Coil Type/Material DVC / Black Aluminium
Xmax (lin/peak) 10/20 mm
Ce fel de incinta ar fii cel mai recomandat bassreflex sau bandpass ????
Poate aveti la indemana niste scheme ceva .
Multumesc
![Smile](https://www.loganclub.ro/forum/core/images/smiley/smile.gif)
Magnet weight 80 oz
Mms 146 g
Size 322mm ( 12" )
SPL (1W/m) 87.6 dB
Multumesc
