Dimensiune cauciucuri Logan Cupa
  • Dimensiune cauciucuri Logan Cupa
    cine are idee pe ce dimensiuni sunt gumele puse pe loganurile de cupa ...
    cele cu jante ATS ?
    LOCUL1 140.6dB-LOCUL2 138.9dB
    LOCUL2 140.1dB-LOCUL2 Mini1000 141.9dB (newCID)
    LOCUL1 143.9dB (nCID)
    185/50/15 sper sa nu gresesc.
      Logan Cup:
      Chassis :
      steel monocoque with bolted roll cage
      aerodynamic feature: Rear spoiler (circuit version)
      Engine
      layout: Front transversally mounted
      type: Renault K7M, 4 cylinder, 8 valve, 1598cc
      bore x stroke: 79.5 x 80.5mm
      fuel injection: Multipoint
      maximum power: 64kW (90bhp) at 5500rpm
      maximum torque: 128Nm at 3000rpm
      Transmission
      type: Traction
      gearbox: Ricardo JH3 5 speeds gearbox + reverse gear
      gearshift: In H config
      clutch: 200mm single disc
      Axes and suspension systems
      front: McPherson-like suspension system with triangular wishbone, Bilstein shock absorbers and specific springs
      rear: H-shaped axle with torsion-beam suspension and programmed deflection, Bilstein shock absorbers and specific helicoid springs
      Brakes
      front: 259mm solid discs
      rear: 8” drum brakes
      wheels: 6x15” standard steel or Toora Competizione aluminium wheels
      tyres: standard 185/65 R 15 or Michelin Exalto 185/55 15
      Dimensions
      length: 4247mm
      overall width: 1740mm
      height: 1534mm
      wheel base: 2630mm
      front - rear track: 1466-1456mm
      cx: 0.36
      fuel tank: 50 litres
      weight (unladen): 1030kg (rally versions)
        multam ...
        m-a mai ajutat cineva cu un link ...
        acolo scria ceva de genu 195/50/15
        dunlop direzza ...
          Eu am luat de pe wikipedia. Mi se pare cam ciudat sa se mearga cu talon de 65 ... deci 195/50 e mai plauzibil.
            Deci: decit sa va dati cu parerea aiurea, mai bine stati in banca voastra. Omul a intrebat despre Loganul de circuit
            185/55/15 sunt Michelin-urile care se folosesc la Loganul de raliu, cele de circuit au anvelope mult mai late, nu stiu exact care ar fi dimensiunea. Un telefon la Racing Nick rezolva problema, ca el avea de vinzare anvelope d-astea.
            _
            B 48 C U P - Ligheanul Agitat
