Modificare Chiulasa
  • #46
    Salut , am vazut ca cei de la renault au obtinut 128cp din motorul k4m, ajungand la un raport de compresie de 11 la 1 si axe care deschid supapele 11mm in loc de 9mm versiunea de baza. pun si si scrie acolo:
    The New Renault Clio range includes the new 1.6 16V 128hp engine (Type K4M HP) which is notably available for the GT version (depending on market). Maximum power is 128hp (94kW) at 6,750rpm, with peak torque standing at 155Nm at 4,250rpm. This normally-aspirated powerplant is responsive and delivers outstanding performance: with this new engine under the bonnet, New Clio Hatchback accelerates from standstill to 100kph in 9.3 seconds. Fuel consumption, however, is a low 6.9 litres / 100km (equivalent to 160g of CO2 / km) thanks to specific tuning and the fact that it drives through a six-speed manual gearbox.
    The 1.6 16V 128 engine has been developed from the 1,598cc petrol engine. The majority of components are shared with the Twingo Renault Sport engine. The additional power and torque stems from several modifications:
    - increased intake airflow rate thanks to a specific throttle valve unit and aluminium plenum chamber, plus optimization of the intake port diameter and length.
    - to improve airflow into the engine and facilitate gas flow, work has gone into the aerodynamics of the valve seats. The camshaft calibration has also been modified to achieve a longer opening of the valves and higher valve lift (11 mm, instead of an average lift of 9 mm)
    - The geometry of the combustion chambers and pistons has led to a high compression ratio of 11.0:1 for enhanced combustion quality, and therefore greater efficiency and cleaner emissions.
    - The continuously variable inlet camshaft ensures improved performance at all engine speeds. The actuator adjusts the timing to optimize valve opening and closure.
    - This engine incorporates a compact, four-into-one thin-walled steel exhaust manifold which includes a catalytic converter. It ensures a first class compromise between performance and minimizing emissions.
    si adresa http://autodrum.com/cars/renault/reviews/clio_2010/
    deci se poate...
    • #47
      pai normal ca se poate , doar ca sa ajungi la 11 compresie , iti trebuie pistoane de compresie mai mare .
      Plus ca mie asta imi suna a distributie variabila
      • #48
        si aer mai mult ... pt ca o sa mearga bogat de tot
        sigpicMy ride
        • #49
          Normal ca trebuie sa schimbi aproape tot motorul dar macar e un exemplu , daca cineva nu are de lucru si vrea sa-si faca... parerea mea mai bine cauti un clio cu motorul k4m de 128cp dauna totala numa il pui pe logan, sau mai e k4m pe clio turbo...altfel axe si remapare... dar eu unu nu's adeptu axelor pt ca nu-mi place cum suna motorul mai ales la relantiu
          • #50
            ala K4M turbo e tare , pana acum n-am auzit de el )
            plus ca nimic nu se compara cu relantiul frumos de la o masina cu axe modificate
            • #51
              Chiar exista http://www.youtube.com/watch?v=B8CYdUTtwdg nici eu nu am stiut pana nu am vazut
              • #52
                pai asa exista orice masina turbo ) ,asa avem si 1.6 kompresor ,
                ca ii pui dup-aia . Renaultu nu produce asa ceva .
                • #53
                  Am si eu o intrebare , avem vreun coleg care a schimbat axele cu unele sport pe 1.6 16v? si eventual ceva pareri...si ce ar mai trebui schimbat pe langa soft?
                  • #54
                    ss
                    eu zic sa mergi undeva si sati iei una de la o masina tamponata ii mai simplu
                    • #55
                      A fost mai demult,1.6 16v cu serpi,evacuare pe 50mm fara catalizator,filtru K&N in carcasa originala,axe si soft si scotea 123cp.fara axe undeva la 117cp.Daca nu ma insel avea cuplu de 144Nm,fata de 148stock.Posibil ca nu avea softu prea potrivit.Uite niste clipuri cu el.
                      AG 16 Y M A
                      • #56
                        in germania, un tip si-a pus pe un clio de 1.6_16v axe catcams de 264 de grade si-a ajuns cu evacuare si filtru sport la 133cp si vreo 170-180Nm. deci se poate
