Problem With Water Drain From Evaporator
  • Problem With Water Drain From Evaporator
    Hello There. Im new here at the club. Im from Venezuela, yes very far.... I have a Renault logan 2007. I chaged by myself the evaporator of the air conditioner that was damaged, but now i have a problem with the drain of the water of the evaporator and the carpet is full of water, the floor of the co-pilot seat is full too. I think i lost a hose or something like that , that sends the water out of the car. Can someone help me with this??? have someone a manual ???
    Thanks and best regards
    hello, it's possible(most likely) to have the drain hole of the air conditioned clogged.
    kind regards
      yes, look at the car floor and above the catalyst you'l see a small hole with some rubber/plastic around it. take a plastic stick or a piece of wire and slowly try to re-open that hole. carefull, don't insert it too deep (2-3cm should be more than enogh) and watch not to get wet.
